who is using a DRUM mower ?
   / who is using a DRUM mower ? #11
yes I understand the purpose of the conditioner, just not sold on the big benefit with orchard grass as it is not as stalky as other crops. Mowing 3-4' tall hay @ 1 mph @ 540rpm. the conditioner rolls are set right and the knife is sharp. The Reel speed seems slow but I cant find any info on how to speed the reel up. Also lets not forget about storage I really dont like leaving equipment out and I have no room to store it. I do find it interesting that know one that owns and uses a drum mower has given me there input, im thinking not many are using these lol
Mike, drum mowers are good cutters. Just slower in coverage due to width. If you hit really tall thick stuff they can ball up the hay. You can get a good used one at a fair price and it will do a good job with low maintenance. I found one in really good shape for 1k but wanted something wider. I still should of got it to resell.
If your grass is 3-4' tall and thick you will have some balling of the hay. Other than that they are good cutters.
   / who is using a DRUM mower ? #12
I think your math is incorrect. 3.9 acres per hr will be closer to what your H & 1120 can cut @ 4.3.mph. Old timers formula that's very accurate is mph X width of cut divided by 10 = acres per hr.
I should have been clearer. The usual tractors that I use I can cut my field and my neighbors small field in 50 minutes. The lowly Farmall h is a tad slower but not by much (I have yet to actually time it with the Farmall h. Frankly I have only used the h once and that was for giggles, but I may do it again). Regardless on any of these tractors I am using a hand crank ratchet cyclinder to raise and lower so that is a time handicap. That said, the mowing pattern I am forced to use (due to no hydraulics) is very efficient and I think I can beat your rule of thumb estimation formula anyday with even my well worn unit. I simply mow roundy roundy towards the center like outline in the antique sickle mowers books. I am always mowing there is no wasted travels in my mowing pattern at all.
What I was trying to convey is that the OP who has a nice JD tractor (and he also has a Farmall h) should be able to easily do 4 mph hour or more with either tractor. If not something is wrong with that haybine and needs corrected. Regardless, though of how nice a tractor he uses 6 mph will be about the practical maximum limit of the haybine.
For the record: I have nothing against drum mowers either, but the OP already has the haybine and he only has 6 acres.
   / who is using a DRUM mower ? #13
Every 90 degrees corner you turn with your Hesston cutter no matter what tractor you pull it with the cutter back ups on the roundy,roundy corner. At 4 mph there's no way to cut 5.5 acres with a 9 ft cut cutter in 50 minutes PERIOD FYI your Hesston isn't a Mo-Co or Haybine. Both those names are Trademarks of JD & NH respectfully. After 25 yrs in the custom hay baling business this ain't my first rodeo. I hope you have a wonderful day,Jim
   / who is using a DRUM mower ? #14
...FYI your Hesston isn't a Mo-Co or Haybine. Both those names are Trademarks of JD & NH respectfully
Yes I am aware of the trademark names. Do not believe I ever referred to my mower conditioner as a haybine or a Mo-Co. I did call it moco which is fine if JD only trademarked Mo-Co. If I dare stepped on a JD trademark then pardon me.
   / who is using a DRUM mower ? #15
The old timers' formula assumes a field efficiency of 82.5% -- in line with published estimates in the ag. engineering literature.
The theoretical capacity for a 9' swath at 4.3 mph = 9'*4.3mph/8.25 = 4.69 acres/hour. Rankrank1 has overestimated the field size and/or underestimated his ground speed.
Steve
   / who is using a DRUM mower ? #16
Steve
If you read all my posts. I clarified that I had not done it in 50 minutes with my lowly Farmall h which is only 4.3 mph in 3rd gear. Still it was not all that much slower. The tractor I normally use is faster, I do not know the actual speed on it though as I have seen 2 different possibilities published for it. I need to lay out a distance and get my stopwatch out so I confirm its speed in the gear I use before I argue further.
You are also correct in that I may be overestimating my acres slightly. While I know what is in my field, I have relied on the neighbors info for his field. I need to either measure it or find a free google earth program to confirm his information to me again before I argue further.
Until then if we want to continue the pissing match my mower conditioner is actually 9' 3" cut.
1 acre = 43560 square foot
(4.3 mph x 5280 ft x 9.25' cut = 210012 sq ft/hour) then (210012 / 43560 = 4.82 acres per hour theoretical).
(4.6 mph x 5280 ft x 9.25' cut = 224664 sq ft/hour) then (224664 / 43560 = 5.16 acres per hour theoretical).
(4.9 mph x 5280 ft x 9.25' cut = 239316 sq ft /hour) then (239316 / 43560 = 5.49 acres per hour theoretical).
(5.2 mph x 5280 ft x 9.25' cut = 253968 sq ft/hour) then (253968 / 43560 = 5.83 acres per hour theoretical).
(5.5 mph x 5280 ft x 9.25' cut = 268620 sq ft/hour) then (268620 / 43560 = 6.17 acres per hour theoretical).
(5.8 mph x 5280 ft x 9.25' cut = 283272 sq ft/hour) then (283272 / 43560 = 6.50 acres per hour theoretical).
Of course these are theoretical 100% max efficiencies which are impossible in real world. You do not get a full cut each time (the efficiency here depends on overlap operator provides on each lap. The least amount of overlap improves efficiency). Also you are not always travel in straight line (efficiency here depends on pattern operator chooses to mow field - some patterns are much more efficient than others. Any time spent not cutting hurts efficiency. Some fields will be more efficient to mow than others due to their shape).
Again my original point to the OP was intended to be that even his lowly Farmall h should not be all that slow on his haybine. The OP's nice JD tractor should be even faster. The OP is mowing at 1.0 mph. Something definitely wrong with his haybine but that's all been lost now.
   / who is using a DRUM mower ? #17
I do fully agree with your "last statement"!!!!!!
No urinating on my part but don't get any of yours on your toes. All your mathematics won't make it happen even if you have a 9' 3" cut hay cutter. It's impossible to cut with 100% efficiency. On the JD trademark infringement I could care less. I was just trying to let you know that Haybine & Mo-Co were trademarks and that you had neither one in a Hesston. So have a nice day,Jim
   / who is using a DRUM mower ? #18
If the field was 5miles long he could do it on the 1st pass. :confused3:
larry
   / who is using a DRUM mower ? #19
larry
That's true and IF a frog had wings it wouldn't bump it's hinny every time it jumped!!!!!!!!:cool2:
   / who is using a DRUM mower ? #20
I have had some experience with a friends Reese drum mower. They use it on a 40hp Allis and it works well. You can mow as fast as the tractor can pull it. It does windrow or "ball up" the hay a bit but nothing to bad. My biggest complaint is that it is pretty top heavy in the transport position. It folds up with hydraulics instead of just swinging to the rear like other manufactures.
John Deere 3025E (A53317)
John Deere 3025E...
Sedan (A59231)
Sedan (A59231)
*Selling at Royal Auction Zephyrhills, FL Location* (A59231)
*Selling at Royal...
25 DUAL AXLE GOOSENECK TRAILER (A55745)
25 DUAL AXLE...
Billy Goat Multi-Vacuum (A56860)
Billy Goat...
Misc Pallet of Chains and Bucks (A57454)
Misc Pallet of...
