Forks Who has a set of JD pallet forks for 430 loader???
   / Who has a set of JD pallet forks for 430 loader??? #1
swa240z
Southern Indiana
JD 4300 HST MFWD
I like the simple design of the quick tach JD pallet forks and was wanting to build my own based on that design. There aren't any to look at in my area, so I need some help on the dimensions from those of you who own these. I'm looking for the following:
Dimensions and length of top and bottom square tube
Dimensions and thickness of the side plates
Dimensions and thickness of the middle support plates
Distance between the middle support plates
Diameter of the fork mounting rod
Distance from center of fork mounting rod to bottom of side plate
Height of fork to center of mounting tube
Thickness of mounting plate where loader frame attaches
I also plan to add mounting points for 3PH use and possibly a grapple. This will be my first project with my new welder - a Millermatic 210. Can't wait to get started! My biggest problem (other than needing the measurements above /forums/images/graemlins/smile.gif ) is finding a set of used forks - I have looked everywhere!
Thanks for any help you can give me!
Steve
swa240z@insightbb.com
   / Who has a set of JD pallet forks for 430 loader??? #2
Steve,
I received your PM and haven't forgotten about you. /forums/images/graemlins/wink.gif I'll try to go out this evening and measure up all these dimensions on my forks and get back to you by PM. Please be patient....I'm wrapped up in a lot of things right now.
...Bob
Thanks Bob. I wasn't sure you got my PM since it didn't show up in my list of sent PMs for some reason. I was going to send a follow-up PM, but I couldn't remember who I had sent it to. /forums/images/graemlins/confused.gif
Thanks again!
Steve
   / Who has a set of JD pallet forks for 430 loader??? #4
Will have time this evening to measure up what you are looking for. I'll post here instead in the forums for the benefit of all.
...Bob
   / Who has a set of JD pallet forks for 430 loader??? #5
Steve,
Here's the information you're looking for. These measurements are for the JD pallet forks that fit on JD's 460 loader (I believe it's the same as what fits on the 430 loader). See pic attached.
<font color="blue"> Dimensions and length of top and bottom square tube </font>
Square tube is 3" x 3". Both tubes are 53 1/2" in length.
<font color="blue"> Dimensions and thickness of the side plates</font>
Side plates are trapezoidal in shape. Top is 4 1/2"W. Bottom is 8" wide. Plate is 21 1/2" high. Plate is 1/4" thick.
<font color="blue"> Dimensions and thickness of the middle support plates </font>
4" wide x 15" high. Plate is 1/4" thick
<font color="blue"> Distance between the middle support plates </font>
10 3/8"
<font color="blue"> Diameter of the fork mounting rod </font>
1 1/2"
<font color="blue"> Distance from center of fork mounting rod to bottom of side plate</font>
16 1/2"
<font color="blue"> Height of fork to center of mounting tube </font>
18 1/4"
<font color="blue"> Thickness of mounting plate where loader frame attaches </font>
1/4 "
Hope all this helps you out.
..Bob
   / Who has a set of JD pallet forks for 430 loader??? #6
<font color="blue"> My biggest problem (other than needing the measurements above ) is finding a set of used forks - I have looked everywhere! </font>
Northern Tool sells new ones, I've been looking for used ones also. If you are near a large town, they often have forklift junkyards. I'll let you know if I find any.
rancar -
Thanks a bunch for the measurements. I think those will get me pretty close.
I'm still looking for some good used forks, so if anyone in the central Indiana area knows where some are, let me know.
I'll post some pics as soon as I get mine all put together.
Thanks again!
Steve
   / Who has a set of JD pallet forks for 430 loader??? #8
Here is a picture of my dads home brew pallet forks for his loader. You can see he rigged it for either the loader or 3 point hitch in the rear.
Jim
   / Who has a set of JD pallet forks for 430 loader??? #9
Your Dad does some nice work. /forums/images/graemlins/smile.gif Any chance of some more pictures and maybe some 'how to' and materials used? I'd like to make one myself. I especially love the convertible front-to-rear feature.
   / Who has a set of JD pallet forks for 430 loader??? #10
I'm attaching the only other picture I have of the forks. He built them originally for my uncles Allis Chalmers. He just got the little Deere last month and my uncle didn't need them any longer so a re-work was in order. Other than the forks, I believe he said all the materials came out of the "scrap metal" pile.
He does read the board fairly regularly, so hopefully he can give you the specifics.
2017 Ford Transit 350 Handicapped Van (A53422)
2017 Ford Transit...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2003 Walk-Behind Automatic Seed Spreader (A54811)
2003 Walk-Behind...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
2001 Ford Ranger Pickup Truck (A51694)
2001 Ford Ranger...
