Bought the attached rototiller new at an auction last year, with only the single page included for documentation. Any ideas? There isn't even a serial number plate.
Most likely. I'm just trying to find some documentation in order to troubleshoot. Concerned there may be a gearbox issue. Splines will not turn once resistance is applied (into the ground). Can't find a sheer pin anywhere, likely as it has a PTO slipclutch.
I thought maybe that was the issue at first, but it's grabbing. I can't tell where it's slipping, gearbox output is hidden. Might just have to bite the bullet and drain to inspect.
Most likely Chinese. Drain the side gear box and open it up. There should be a broken gear pin inside you need to replace. This happened to my friend who bought the Chinese one.
I actually opened up the side gearbox last night before your post. Turns out it was fine so I dug a little deeper. After burning off a bunch of baler twine I found the culprit (attached). Not a good sign if the weld broke that easy. Mind you I knew what I was getting into when I bought this unit,,,
