Tiller Who can identify this rototiller?
   / Who can identify this rototiller? #1
Finn73
Canada
Bought the attached rototiller new at an auction last year, with only the single page included for documentation. Any ideas? There isn't even a serial number plate. IMG_2428.JPGIMG_2429.JPGIMG_2430.JPGIMG_2431.JPG
   / Who can identify this rototiller? #2
That looks to be a Made in China tiller.
Most likely. I'm just trying to find some documentation in order to troubleshoot. Concerned there may be a gearbox issue. Splines will not turn once resistance is applied (into the ground). Can't find a sheer pin anywhere, likely as it has a PTO slipclutch.
I thought maybe that was the issue at first, but it's grabbing. I can't tell where it's slipping, gearbox output is hidden. Might just have to bite the bullet and drain to inspect.
   / Who can identify this rototiller? #6
I'll go with made in India and that it's a very good quality tiller.
Any chance it's sold in North America under a familiar name? I've been googling but nothing looks quite the same
   / Who can identify this rototiller? #8
Most likely Chinese. Drain the side gear box and open it up. There should be a broken gear pin inside you need to replace. This happened to my friend who bought the Chinese one.
I actually opened up the side gearbox last night before your post. Turns out it was fine so I dug a little deeper. After burning off a bunch of baler twine I found the culprit (attached). Not a good sign if the weld broke that easy. Mind you I knew what I was getting into when I bought this unit,,,IMG_2432.JPG
   / Who can identify this rototiller? #10
OH wow, I've never tried to weld anything big, or really much at all. But if I did, I think I would do better than that.
Is that something you think you can do yourself?
2002 Trotwood Trailer (A50515)
2002 Trotwood...
International 5088 2wd Cab Tractor (A52128)
International 5088...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
GEHL RB1470 TOTAL DENSITY CONTROL HAY BALER (A51243)
GEHL RB1470 TOTAL...
2011 Ford Utility Econoline Van (A50515)
2011 Ford Utility...
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
