Mowing Who can help: serial # for 72 inch mower deck
   / Who can help: serial # for 72 inch mower deck #1
MGADon
CT
JD 870
Hi,
I'm looking at a 72 inch mmm deck , John Deere serial Moo297x59576, (as relayed to me). Will this fit an 870?
I believe I can use any deck from the x55 or x70 series, with the proper brackets. Thanks.
Don
   / Who can help: serial # for 72 inch mower deck #2
Don, you are correct, it will fit , however your mounting (lift)
arms my be different and can run into $$ The M00297X series
was used from the late 80's to the late 90's on both x55 and x70 series tractors. It was a very good deck.
   / Who can help: serial # for 72 inch mower deck #3
I'd go to Deere's parts on line reference and pull down the various exploded drawings. Clearly shows what parts are needed for what models. If this deck was used on a different model you might have to dig around a bit and print out the equipment lists for both.
I bought a used 60" deck from a 955 for use on my 855. Came without any of the mounting hardware, so I used the partslist / drawings to figure out what I needed. Brackets cost more than I paid for the deck, so I fabbed my own using the pictures and a unit at the dealers lot for reference. But wasn't hard to figure out it would work.
Thanks Guys. Here's an update:
I have the deck (Ebay) on it's way here in a few days.
I also have a fellow who can sell me most of the bracketry left over from his swapping a deck from an 870 to an 855.
I'm going to the JD site now to try and figure out what I'm missing.
Don
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
KatoLight L3SFGH4 (A47384)
KatoLight L3SFGH4...
2009 Ford F450 Dump (A47384)
2009 Ford F450...
1991 Double Tandem Trailer (A50514)
1991 Double Tandem...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
