who all uses synthetic oil?
   / who all uses synthetic oil? #1
wango tango
Peoria IL
i believe my 4410 calls for 15w40. going to change it this weekend and was wondering how many of you all use synthetic oil?
   / who all uses synthetic oil? #2
At my 50 hr. maint. schedule, I plan on going to Rotella T synthetic. The manual states that CJ-4 is not suitable for this tractor, but another thread I came across http://www.tractorbynet.com/forums/...37502-cj-4-rated-engine-oils.html#post1594582 said Kubota has not updated their manuals to include the CJ-4 rating. I have used Rotella in everything else. It's a heavy duty oil designed especially for hotter running diesel engines, but I run it in all of my engines, from mowers on up to my vehicles, gas or diesel.
   / who all uses synthetic oil? #3
I run Archer-Kendall 15/40 Dino oil (non-synthetic)in my Duramax and do oil analysis every oil change and it is perfect..Syth and soot have something to do with it I think..Not sure. I have forgotten.
   / who all uses synthetic oil? #4
Hiya,
I use Amsoil in every gasoline, Diesel or propane fueled machine I have or currently own since 1978. Same goes for transmissions, hydros, differentials and transfer cases. Never any issues, nuff said.
Tom
   / who all uses synthetic oil? #5
As I stated on another thread!
"I used to use Mobil #1 but after using Royal Purple at work in some real abusive situations on some big gear drives and seeing how well it preformed I switched my F350 over to it and it is running cooler, quieter, and 2.5 mpg better mileage."
I run it now in all my stuff, Trucks, tractors, lawn mowers, and anything that has a crank or gear case.:thumbsup:
   / who all uses synthetic oil? #6
I must ask if any of you have done oil analysis? I like facts..
   / who all uses synthetic oil? #7
I have no idea what John Deere put in my new 3720. But it was a quart low on delivery. I put in the same Mobil 1 0W40 ECF that's spec'd for my Mercedes turbo diesel. That's what I plan to put in the 3720 at it's first scheduled oil change as well.
//greg//
   / who all uses synthetic oil? #8
My local JD dealer gives me a great deal on JD 0w-40w synthetic. It's cheaper than Mobil 1 and Rotella T at Wally's.
I have switched every "HydroCarbon" burner I (we) own over to it!
AKfish
   / who all uses synthetic oil? #9
I am using Amsoil 15w40 in the engine, I am also using the Amsoil synthetic in the transmission/hydraulic and front axle..
over on bob-is-the-oil-guy the JD synthetic engine oil has gotten good reviews, and is priced competitively..
Brian
   / who all uses synthetic oil? #10
Amsoil 10W30 in all my engines
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
2016 Club Car Carryall 1500 4x4 Utility Cart (A53424)
2016 Club Car...
2005 Kaufman Trailers Trailer, VIN # 15XFW53265L001140 (A53421)
2005 Kaufman...
1979 MACK R MODEL WINCH TRUCK (A53843)
1979 MACK R MODEL...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A54757)
UNUSED WOLVERINE...
