White Smoke
   / White Smoke #1
willhoff
new concord, ohio
john deere
I have a JD diesel engine that blows white smoke going down a hill. When I start back up the hill it clears up and runs fine. The engine does not use any oil. What should I look for??
   / White Smoke #2
water in the fuel tank...
   / White Smoke #4
I always attributed white smoke to unburned fuel to start with. It can be other things but unburned fuel is most common I think. You will see it when cranking before it starts. If you had white smoke all the time and it was hard to start I would suspect a compression problem But just down hill I don't know weather that is a worry or not.
   / White Smoke #7
Is the coolant level steady?
   / White Smoke
That was one of my thoughts.. I drained the fuel filter several times >> that didn't help? I put a new filter on the tractor >> that didn't help? I did not see any water in the fuel when I opened the drain.
ROCK PICKER (A52472)
2013 PETERBILT 367 (A52472)
2013 PETERBILT 367...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2025 New/Unused Wolverine Point Quick Hitch (A51573)
2025 New/Unused...
2019 Chevrolet Tahoe LT SUV (A51694)
2019 Chevrolet...
FRONTIER MG20F LOT NUMBER 82 (A53084)
FRONTIER MG20F LOT...
