White Smoke
   / White Smoke #1
willhoff
new concord, ohio
john deere
I have a JD diesel engine that blows white smoke going down a hill. When I start back up the hill it clears up and runs fine. The engine does not use any oil. What should I look for??
   / White Smoke #2
water in the fuel tank...
   / White Smoke #4
I always attributed white smoke to unburned fuel to start with. It can be other things but unburned fuel is most common I think. You will see it when cranking before it starts. If you had white smoke all the time and it was hard to start I would suspect a compression problem But just down hill I don't know weather that is a worry or not.
   / White Smoke #7
Is the coolant level steady?
   / White Smoke
That was one of my thoughts.. I drained the fuel filter several times >> that didn't help? I put a new filter on the tractor >> that didn't help? I did not see any water in the fuel when I opened the drain.
2023 AGT Topcat Stump Grinder (A51573)
2023 AGT Topcat...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A52472)
2014 AMERITRAIL...
2011 ORTEQ ENERGY SERVICES 40 MANIFOLD TRAILER (A52472)
2011 ORTEQ ENERGY...
2012 John Deere 7230R (A52748)
2012 John Deere...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
