Buying Advice White 2-65/Iseki T7000 Starter HELP!
   / White 2-65/Iseki T7000 Starter HELP! #11
I looked at the price for that starter and that
is just a ridiculously high price.
   / White 2-65/Iseki T7000 Starter HELP! #12
If you want to stick with the original starter, I can probably fix it.
Lens Thanks for the offer.
I found a seller on EBAY for the 'new version' for 100 bucks. I figure for that price I can take a chance to see if it will fit.
Should be able to find some time this weekend to try and put it on
UPDATE:
The new generation version works!! for $125ish bucks I am back in business. The upside is it weighs about 1/2 as much so its easier to manage AND because its shorter in length the starter no longer interferes with the return to the hydraulic filter. I was concerned that because it looked taller and the motor portion was angled that it wouldn't fit in next to the steel panel that bolts on to protect it.
Thanks again for all the suggestions and help.
Cheers
2002 Wacker RD11A Tandem Smooth Drum Roller (A55851)
2002 Wacker RD11A...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2018 JLG 2632ES 26ft Electric Scissor Lift (A53421)
2018 JLG 2632ES...
2009 CAT 140M MOTOR GRADER (A55745)
2009 CAT 140M...
2013 VOLVO TRUCK VNL (A55745)
2013 VOLVO TRUCK...
Toro Multi Pro 5800 (A53424)
Toro Multi Pro...
