Whistling noise
   / Whistling noise #1
blake037374
Baton Rouge, LA
CT440
Free working with tractor for hour or two. Only when I go in reverse sometimes I hear a whistling noise. And if I ease off to go slower it stops but will happen if I press harder again. Not sure if it's normal. Have any of you heard this.
   / Whistling noise #2
Yes there is a kit to fix this problem..It only occurs in reverse and only after the fluid is hot. The kit is easy to retrofit it replaces a banjo bolt and adds a high pressure dead ended hose.
http://www.tractorbynet.com/forums/...ving-reverse.html?highlight=squeal+in+reverse
Part numbers from the parts bags they came in, are as follows: New style eyebolt to replace existing~ part # T4125-39101.
Attenuator hose: part # T4125-39001
Cord band,(cable tie) part # T2185-82551
   / Whistling noise #3
This thread has been very helpful! My Bobcat CT335 also exhibits this squealing sound when warmed up and in reverse. After reading through
the thread referenced by James K0UA, I checked the parts list for the external hydraulic lines for the CT335, and have attached it in PDF
format to this message. It shows the new banjo bolt and dead-ended hose (items # 23 and 24 on the diagram) as a replacement for the original
bolt (item #19 that attached the rigid pipe from the HST filter assembly to the HST).
My CT335 (2012 model) does not have this dead-ended hose. I couldn't find any mention of this in the CT35 shop manual. The
attached diagram does show the appropriate part numbers for the dead-ended hose and banjo joint bolt.
You can find the parts list breakdown diagrams on the Bobcat website by clicking on the Parts & Service tab and clicking on Service & Maintenance
and then click on 'Go To Parts Catalog'. Select your tractor model to obtain a list of sub-assemblies. Select the External Hydraulic Line Group.
Make sure that you use Internet Explorer for this as it doesn't work with Firefox.
  • CT335 HST EXT HYD LINE Gp.pdf
   / Whistling noise #4
I can attest that it works, I have the kit in mine. Mine only did it when the fluid was run for at least 2 hours hard in hot weather. And the sound was pretty mild, but it was there. After the kit was installed, it is gone.
   / Whistling noise #5
Did you install the kit yourself, or did the dealer install it??
   / Whistling noise #6
We installed it together in my driveway. Anyone could install it. It is just a few minutes with a wrench.
Butterfly Artwork (A55758)
Butterfly Artwork...
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
Hydraulic Hose and Fitting Replacement Pack (New/Unused) Est Retail Value $2,650 (A59225)
Hydraulic Hose and...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52709)
(INOP) 2016...
JOHN DEERE 6500 HI-CYCLE SPRAYER (A52708)
JOHN DEERE 6500...
