Whining noise and power steering shudder on Mahindra 3616
   / Whining noise and power steering shudder on Mahindra 3616 #1
Laffyridge
Troutville, VA
Mahindra 3616
Hey there...invaluable forum!!! Spending WAY TOO much time on here :)
I have a Mahindra 3616 shuttle with only 15 hours...barely had time to use her but looking forward to spring and summer! When I am using it I often hear a whine and then feel a slight shutter in the steering...sometimes I loose power steering but only for a second and it comes right back. I have checked the hydraulic fluid and it's full (checked it on level ground both when it was warmed up and cold). Also moved the steering wheel back and forth for a long time while running to see if there was any air in the lines. Any suggestions? Would hate to have to have dealer come and pick it up when I just got it!
Thanks!
   / Whining noise and power steering shudder on Mahindra 3616 #2
I would check and tighten all of the suction line fittings. Sounds like it is getting air in the system.
Hey Galen thanks so much for your reply! Where do I find those fittings?
   / Whining noise and power steering shudder on Mahindra 3616 #4
There would be several joints in the line from your transmission housing to the hyd filter and on to the hydraulic pump.
   / Whining noise and power steering shudder on Mahindra 3616 #5
I bought a 3616 last fall with 166 hours and it does the same thing every once in a while. The dealer I got it from said it's normal, not a problem.
   / Whining noise and power steering shudder on Mahindra 3616 #7
When was the filter last changed? If this has an inlet filter on the pump & if it is partially plugged it could also cause this problem. Use an OEM filter if it is a inlet filter.
Genie GTH1056 (A50120)
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2002 Freightliner FL70 Sweeper Truck (NOT RUNNING)(TITLE) (A50774)
2002 Freightliner...
