whining hydrostatic
   / whining hydrostatic #41
You will need to shut it off to check the fluid. Are there high and low marks on the stick?
yes and it reads at the very bottom add mark
just made sure the loader was down it still reads low
   / whining hydrostatic #45
Page 89 shows the grease you need to use for your sticky hydro pedals.
   / whining hydrostatic #46
Yes I have played around with it a little and found that the whine is alot less in low range about 1800 or so rpms. Im kinda nervous about how long i use it due to the fact that I am really not sure if I am low on fluid or not, It seems to be reading at the very lowest mark on the stick with it wamed up and shut off. I am going to call the dealer tomorrow to see if its supposed to be checked running or off.The bucket and hoe seem to be working fine with no whine at all its just the peddle that seems to whine when pressed.Could the fluid being a little low add to the whine even if the other hydraulics are silent?The tractor is a leftover and has set for a long time the place i bought it agreed to put a thumb on it and load the tires maybe they over looked checking the fluids(no excuse but possible)I also need to find out if the peddle returning up is suppose to be kinda slow it takes about 3 secs to come back up another thing i should say is that it hasnt been much warmer than low 30s here all wk
If they added a hydraulic thumb, that's another circuit and cylinder to get filled with hyd. fluid. If they forgot to add more fluid when they did this, it could explain why it's low. The other thing is exactly what kind of fluid is in it? Don't know if Mahindra has a recommended hydraulic fluid, but if it's anything like Kubota, they insist on their own OEM hydraulic fluid, and owners have reported a real mixed bag of results using other products.
the pedal doesnt seem to be sticking it comes back up like a hatch would on a car i just pushed it down all the way and it took 5 secs to come up to normal its spongy like
its a manual thumb the backhoe is on would that not allow the 3pnt from being put down all the way?
   / whining hydrostatic #49
It's LOW on fluid. Find out what's recommended and fill it gradually until it is between the marks on the stick, AFTER having brought it up to operating temp on the gauge on the dash. Fill it, check it with the tractor turned OFF.
Your pedal may be sticking/spongy/ slow, whatever due to the tractor sitting on the lot for a long time without use. There may be rust between the pedal shaft and sleeve. It may have to be taken apart and cleaned to make it operate properly. Have the selling dealer fix it or do it yourself.
Do you store it inside or out?
   / whining hydrostatic #50
It's never a bad thing to read the manual's specific instructions about lubing and fluid checks. ;) Most will advise the proper positions of cylinders/attachments when checking, & checking warm with the engine off seems the common way. (read-up to be sure) Sometimes having things out of position could make up half the difference between 'full' & 'add', but being so near the latter would have me adding a bit of hydro. Backhoes, thumbs, etc may not be mentioned, but bubbles in the fluid says your way low.
My NH 1520 HST never seems to whine. It's high on hours, wear & tear, but the FEL works pretty well at 1500 RPM, tho' 1800 is better for heavy lifting. Any more RPM doesn't seem to add much but engine noise, and with only air in the tires & a box blade for balance getting the rear wheels airborne with the FEL is sooo easy when pulling up saplings with the "Brush-Grubber". btw: nothing I've ever heard whines like a Terramite. My drive/pump nearly drowns out engine noise, but the factory has long advised the racket is no sign of trouble. I'm guessing that age/hours will quiet the OP's Mahindra, but each make is so different ...
LOT: (2) Cargo Van Shelving Units, (2) Steel Shelves (A59076)
LOT: (2) Cargo Van...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
TPM RM900SB All Terrain Remote Controlled Weed and Brush Mower (New/Unused) (A59225)
TPM RM900SB All...
2002 Ford F-150 Pickup Truck (A56858)
2002 Ford F-150...
2196 (A58376)
2196 (A58376)
Hydraulic Dingo Trencher Attachment (A55272)
Hydraulic Dingo...
