Not sure what hose you are talking about, but most all the hose are the same size except the suction hose.
The suction hose would be the only hose that you might be able to compress
Have you checked the fluid level and filters?
A hyd pressure gage would be a big help.
With no levers activated, there should be no pressure.
What is the position of the 3pt levers. Should not be if fully raised/max up, but slightly down to neutral.
If all the way up, you will hear the relief going off.
