Grapple Which type of grapple is best suited for...
   / Which type of grapple is best suited for... #351
Serious stage of a buying decision for me is normally 2-3 months of research so he must be getting close. The notional stage can be much longer as that involves justification of an idea and trying to justify the cost but not a lot of detailed research.
For some folks an impulse buy is something that they due on the spur of the moment. For others an impulse buy is something bought in less than a month or two from first seen or thought about to owning it. Of course as the price goes up the length of time to fit within the definition expands as well.
Now I know that for some folks that either have loads of money or view money much differently than others don't see it the same. Isn't diversity of ideas and methods grand?
My wife doesn't distinguish between these various types/stages of buying. She just buys.
LOL... I was ready to pull the trigger on the new EA 48" wicked grapple (they finally built it) but apparently my tractor is too big for it and I would void the warranty.
I'm still waiting for a true front runner. I'm not going to spend the money unless I'm sure...
   / Which type of grapple is best suited for... #353
If there's a front runner that will build a 250 pound compact grapple and warranty it on a 45hp 5000+ pound tractor, I wanna see it.
The 54" and up wicked grapple was designed for, and will be a perfect fit for large compact tractors up to around 50hp.
The 50" single lid will probably do just fine with a larger tractor and a responsible operator, like we, IslandTractor and others have said, BUT it was designed for and works perfectly with small compacts and subcompacts.
   / Which type of grapple is best suited for... #354
If you match the grapple properly, you can abuse it like Ted did in the videos with no worries!!!!
I'm not knocking you guys. I was under the impression, when we all started the conversation about a 50" single lid grapple a few months ago... that it would work on my tractor. I want a single lid grapple. That's why I was waiting for the build. I'm sure I could use it without breaking it... but I'm not going to spend $1300 and have it not warrantied. No biggie. I think that for a smaller tractor, yours IS the front-runner. But now I have to wait for something else take the lead. I think yours definitely looks like a better build piece than the WildKat, Versatech, etc... but again, I don't have unlimited funds to be a guinea pig on something that won't be covered if/when it breaks. Certainly, there will be a point when I will use it to the max capacity of my tractor, so I'll have to wait for something that can handle it.
   / Which type of grapple is best suited for... #356
Why do you want a single lid?
I have watched video after video of both in action and I prefer the single lid. I'm already convinced. Don't want the dual lid.
   / Which type of grapple is best suited for... #358
I would not worry about the warranty on a larger tractor myself. If 1/4" high strength is actually the same as 3/8 mild steel then I can testify it will withstand max lift and breakout with a Kioti DK which is about the same weight and loader size as the Mitsubishi you have.
You destroy grapples with lateral twisting forces, the same that will destroy your FEL. I seriously doubt that Anbo or WRLong would honor the warranty on a bigger grapple for damage that was clearly due to abuse. Mitsubishi will not honor the warranty on a twisted FEL either.
I completely understand what you're saying. However, when I asked, bottom line, if using that grapple on my tractor would void the warranty, EA said yes. So that means that even if I'm using it properly and not abusing it... and it breaks under normal use, then I'm out of luck.
   / Which type of grapple is best suited for... #360
Understood. I suspect they would cover the hydraulic cylinder or hoses and mount and don't see why they would not cover the lid except for twisting. The weakest part of the grapple which they are presumably concerned about is the bottom which has no moving parts and could pretty much only be bent by misuse (Twisting) or root raking with a big heavy tractor. By root raking I don't mean digging but rather the inadvisable practice of treating it like a bulldozer. Tractor FELs are not engineered like bulldozers and tractor grapples aren't either. Maybe they would be willing to specify that they'd cover the cylinder etc.
If it were me, I would ask 1) if they will produce the same grapple in 3/8" mild steel or 2) just buy the one they sell without the warranty.
2014 Ford Escape (A50324)
2014 Ford Escape...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2019 Kia Soul SUV (A53424)
2019 Kia Soul SUV...
2015 Ford Fusion S Sedan (A55853)
2015 Ford Fusion S...
