Which Tranny.
   / Which Tranny.
Okay guys the decision has been made.
First i would like to think everyone for the input i really appreciate of all of the thoughts.
I am going to go with the 4spd m/t and also with the sammy tcase. i got the tcase today and it is so cute. Not very big at all an i tthink it will give me much better gearing options and still keep the wheel base with in reason.
I figure i will have to redo the tranny mount again so why not cut the back half of the tractor off and redo that too..:) lol
I will try to get some new pics and update the thread.
Thanks Crank
   / Which Tranny. #12
I'm not positive but from what I can find the pinto 4 speed gear ratios are: 1st = 3.65, 2nd = 1.97, 3rd = 1.37, 4th = 1.00, Reverse = 3.66 and the Samurai transfer case ratios are 2.268:1 in low range and high range is 1.409:1.
With a 5.14 differential gear and 29 inch tall tires, your slowest ground speed will be 4.1 mph @ 2000 RPM (and a fastest ground speed of almost 24 MPH. :eek: ) By going to a 7.00:1 ratio gear set in the rear, you can get that down to 2.9 MPH. To get a ratio that high, you would definitely have to go aftermarket. I suspect you need more reduction than what you will have with your present setup. (BTW, here's a couple of sites for a speed calculator... 4Lo.com :: Final Gear Ratio, Crawl Ratio, Tire Size Calculators
Speed Potential Calculator For Ring Gear And Pinion Changes)
If you could find a T-18 or T-19 wide ratio transmission, they should have a granny low gear of 6.32:1. With that tranny you could get a speed of 2.3 MPH with the 5.14 gears and 1.7 MPH with the 7:1 gears. Maybe try to find a transmission and transfer case that are already married to each other to ease the installation? Boy! The possibilities are almost endless! :D btw, you probably won't want a spool in the diff.:)
   / Which Tranny. #13
The torque converter would slip most in high gear and the least in low gear. The amount of converter slippage depends on load. In low gear there will be less load on the engine/trans. than in a higher gear.
yes if keep in low you will have less slippage as you have less torque being transfered in the converter unless you have tires that can not slip, I did say that wrong, but the bigger key is the engine RPMs, (even tho I do have a truck with a automatic transmission that is locked solid in third and forth gears and only uses the torque converter in the lower two gears, it was made in 1952).
but if you lug the transmission and most transmissions will jump in to drive very quickly if it is a light load, but if the RPMs of the engine is up, the torque converter will be solider than at lower RPMs and on most tractors you want to run the engine up to its operational RPM, which is normally what would be some below red line in a cars engines situation.
you need to keep the engine above the stall speed of the torque converter,
yes in a cars situation the Rpms of the engine are extremely variable in a tractor they are not, and do to that variable nature of the car there is a lot of slippage in the torque converter, as most auto automatic transmissions do not down shift unless one stops thus they remain in the drive gear, usually only down shifting into second when the vacuum and the throttle lever is moved and kicks it into "passing gear" second,
so unless one put it in a gear and leave it there defeating the automatic nature of the transmission,
the key to the converter is keeping the engine Rpms up above the stall speed of the converter, and very little slip will occurs,
HP25LFUEL - Hughes Torque Converter, Fuel Miser 1200 RPM Stall Speed - HP25LFUEL
Stall speed is the point where a converter has reached it's maximum fluid flow or it has hydraulically locked up because torque multiplication has reached it's highest point.
the higher the stall speed of the converter the more heat would be produced in a variable engine operations, were the engine was operating at or under the stall speed. operation above the stall speed the converter is nearly locked but below the stall speed the convert works to multiply the torque of the engine. but heat is a by product of that torque,
   / Which Tranny. #14
Yes I agree you need to keep the engine in it's "power band"
But just because the engine is turning 2000 rpm and the converter is rated to stall at 1500 rpm dosen't mean it's not slipping, it could be slipping alot.
There are two main reasons:
1. A 12" 1500 stall speed converter for a 1/2 ton pickup with a 175 horse 305 engine may stall around 1500 rpm. But if you yank the 305 and replace it with a 502 CI big block it may stall at 2000 rpm (assuming the tires don't spin and the trans dosen't slip) So stall speed is directly related to the ammount of power your turning the converter with.
2. Stall speed is based on engine speed and input shaft speed and is rated with the input shaft at 0 rpm and wide open throttle. So if the input shaft is turning 1000 rpms and the engine is tuning 2000 rpms under full throttle the converter is slipping and making ALOT of heat. The closer the converter is to "stalling out" the more heat it's producing. A light load will result in low slippage compared to a hard load regardless of engine rpms.
This is why basically all auto trannies from the past 25 yrs or so have lockup converters. There is a clutch in the converter that locks the crank to the input shaft and eliminates slippage while cruising down the highway at light throttle. Better feul milage, lower tranny fluid temps. and lower engine rpms.
2012 International Derrick Digger (A55973)
2012 International...
2000 Nabors 40 Ton T/A Flatbed Equipment Trailer (A55973)
2000 Nabors 40 Ton...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
1290 (A58374)
1290 (A58374)
(INOP) 2016 FORD F150 XL SINGLE CAB TRUCK (A51406)
(INOP) 2016 FORD...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2018 Freightliner...
