Renze
Elite Member
I have a very old single axle trailer with a steel floor, which needs new lights. I use it for scrap, i haul it off whenever the trailer is full. That means its never available for the odd jobs. Because of its condition, scrap hauling has to happen at saturday morning when there is no police on the road, at daylight for safety reasons. There is a pretty good stealth route that takes me over paved farm roads straight into the industrial area in the outskirts of a nearby city, where the scrapyard is located.
I was thinking of refurbishing it, putting the rear axle and wheels of my old car under it because it vibrates so bad, sand blast it at work and put new plywood sides in it. However, it would be a waste to chip off all the new paint when i continue using it for hauling scrap.
So i am thinking of building a brand new trailer for the odd jobs, like hauling a length of tube from work, for home projects. The trailer should be safe but i dont want to haul unnecessary weight and wind drag for a 30 kg steel tube.
Now what should i do?
A. get a one ton runner axle (no brakes) which would give me 750 kg max allowed trailer weight and a total of 350 euro build cost
or B:
Buy a set with 1.5 ton brake axle with surge brake head, which would add up another 300 euro to the build cost...
In Holland, brakes on all axles are mandatory over 750 kg (1653 pounds)
When i build the braked one, i would be a lot safer because i tend to overspeed with small trailers because my TDI tows them so easily (80 allowed, i mostly run 130 km/h because overspeeding more than 50 km/h can cost you your license) but I am still not allowed to tow over 750 kg even when i have brakes, unless i tag it (with license fees etcetera)
So on one hand, using a one ton axle already gives it 25% more capacity than allowed on an untagged vehicle, and when i buy a brake axle anyways, i would rather get a 1.5 ton axle because the price difference is so little. Then, if i already have to pay to get it tagged (plus all the fuss with getting a home built trailer approved) i would rather build a 3.5 ton tandem tilt bed, even thouhj i can also borrow it from my brother whenever i need one....
I think i must concider the cost/benefits before building something...
Whats wisdom ? the cheap route for the odd jobs up to 500kg, borrowing for the bigger jobs ? Or get the safety of brakes even though its not mandatory for many light loads, and stretch the single axle trailer as far as i can go, to get as much benefit from the more expensive running gear which i have already bought for the sake of safety ?
Whatever i build, i would put the axle further back to give it more tongue weight to make it jerk less when empty, and probably use air bags inside the rear axle coil springs of my car.
Then tag it ($$$) or no tag, and taking the risk of still getting a fine because it doesnt have a tag even though it technically is up to any legal requirement ?
or B:
