Which tractor m6800 or L4330
   / Which tractor m6800 or L4330 #11
It sounds like you are answering your own question in looking at the L4330 cab. If you don't have plans that require the M6800, and you want to trailer the tractor, the L4330 is probably going to be a better fit.
   / Which tractor m6800 or L4330 #12
I bought a used Kubota L4310 - HST w/ Ag tires about 4 years ago. I added a Curtis cab w/ heater and also installed a 12V fan mounter behind my head. That makes snow plowing tolerable and the cab (even w/o doors on) also keeps the branches off your face when driving through the woods. You may wish to price the cab add-on to mount onto a M6800. (add your own bigger wiper though).
I think the M68oo is quite a bit bigger. Ask if the transmission is "loader friendly" w/ a hydraulic shuttle. Switching from bucket to forks actually takes 3 hands space about 8' apart, so I just had an ATI quick attach installed on the loader after reviewing some threads here. Some Kubota owners complained that the Kubota-brand detach had some problems.
One important benefit of choosing the M6800 would be a wider track. Review provided remote hydraulic circuits too - ask the dealer for cost to add when comparing
   / Which tractor m6800 or L4330 #13
You better sleep on this one.....otherwise the "bigger tractor syndrome" will forever haunt you if you intend to so some serious agriculture....that's what the M series is all about. Turf tires could be an option bb
   / Which tractor m6800 or L4330 #14
My two cents worth after 3 years with a 4330 HSTC and no immediate plans to switch. When I bought the 4330, I thought I would sell the B-8200, but have been unable to make myself follow through on that. It would be missed.
The factory cab is wonderful, Grand L 40 series are even nicer with improved foot pedal location and a number of trans related gegaws that are nice, but not all that necessary. I REALLY like the lack of direct sun, glare, dust, heat and biting insects in summer and I love shirtsleeves in winter. It is so warm in fact that I frequently have to run the AC to keep defogged. The newer series cab seems to be sealed up better and quieter. Did I mention that I like the cab? Really good chains necessary for winter with R-4's. Duogrips are mediocre at best
Having said that, I regularly wish for more power, weight and width. The 4330runs a 79" kuhn discmower quite well. The M would do it even better with a better sense of security. The M would also be much better for the heavy grapple, but the 4330 does amazingly well. I can work the 4330 pretty hard for 9 hours on 11 gals of fuel. Pretty amazing r.o.i. in that respect. Don't know how the M would stack up. I would make a wild guess of five or six hours on 11 gals.
I have also learned that the cabs are very breakable and have smashed and replaced a fair amount of it. Operator not so smart sometimes. Also,
not great in the woods. Would love to dude it all up like they do in Europe with limb risers, cab protection, skid plates, but that is idle dreaming I'm afraid. Also, every QD implement has required building up the area that the tapered pin closes against so that when loads compress the downpressure spring, the pin does not jump out. I seem to be the only person I know with this trouble; maybe I use it too hard? It just seems like it is only the bottom 3/8ths of the taper that engages it's slot. Have broken those pins too, but if you weld some half inch barstock flush to the opening, problem solved...
So, yeah, I'd like an M, but not at the expense and aggravation of rejiggering all the implements, more fuel, more payments. And one learns to "make do" with what one has. Altogether the 4330 is pretty amazing, and actually it is probably a 4630 now because it will spin the extra hundred rpm that seem to distinguish between the two, not that I run it there anyway, but for the sake of bragging rights. The increase in power from new to broken in (250 hrs or so) was remarkable. Course too, I tried to keep the revs down during the breakin and only rarely run it WFO now. Everyone seems happiest at 18, 1900 rpms, or less.
Some food for thought. Maybe an M with a Cab? That sounds pretty good to me. If you look around on the web, there is lots of second hand machinery if one doesn't mind the risk that used entails. Good luck and remember that anticipation is half the fun. That, and endless hours on TBN.
CASE 850M WT CRAWLER DOZER (A51242)
CASE 850M WT...
2020 CATERPILLAR 326 EXCAVATOR (A51242)
2020 CATERPILLAR...
CRESCENT  MANIFOLD TRAILER (A50854)
CRESCENT MANIFOLD...
1994 LUFKIN (A50854)
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
71068 (A49346)
71068 (A49346)
