LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,140
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
These forums are overly fond of John Deere and Kubota.
From what I've read you are looking at the upper end of the compact utility tractor lineup.
If your situation and useage will allow it I would recommend a cab tractor with good AC.
You questioned about draft control, it is for the 3 point linkage when pulling a 3 point implement,
once set it will raise and lower the implement depending on how the tractor is getting pulled down.
It is not really that usable in most applications, position control is much better for most work,
especially blade and back blades.
Three point mounted disk and harrows or mouldboard plows are the primary units that draft control works with.
Many of the larger units will have tilt and telescoping steering wheels, most everything has Power steering these days.
Also hydraulic applied brakes will make a big difference in operator comfort and control.
I am not a fan of hydro's but other then mowing I wouldn't be surprised to see it be more comfortable for you once you got used to it.
I wish that the newer hydro's had the hand lever controls like the older ag hydro's did, I believe that to be a superior control.
A power shuttle or reverser is my transmission of choice for most work.
Good Luck
Good Luck
