Which Tire Chains
   / Which Tire Chains #1
wvrocks
Bronze Member
Tucker Co, WV
TC-33 DA
I have a NH TC-33DA and I'm looking to get some tire chains for the rear. I have about 1/3 mile gravel drive with 2 fairly steep hills to plow. With small snows I don't have any problem in 4wd. Once it gets packed down and icy or if I have to move a lot of snow I have problems with the back of the tractor "crabbing" around. I use a 7' rear blade and drive forward to plow. Tirechain.com has 4 styles that will fit my 15x19.5 R4's. 4 Link Ladder, Link V-bar Ladder, and 2link Ladder/Vbar ladder. I think i'm going to go with the 4 link version because of cost but can't decide on the V-Bars. I store the tractor in a garage with a concrete floor and not much clearance through the door. I don't want to tear up the floor but I'm not sure if the standard ladder chains will solve my sideways traction problems. Any thoughts?
   / Which Tire Chains #2
The V-bars will increase your traction on ice more than regular chains and also give you an extra dimension of wear surface. However, as you might note, they will add a bit to the overall height. Why not just fold the ROPS when you park it? As far as tearing up your floor, a couple pieces of OSB could serve as a sacrificial surface while you have the chains on. Just lay them where the rears will roll.
   / Which Tire Chains
I have a canopy on the ROPS that really makes it tough to fold. Actually it would probably be taller with it folded. I thought about the OSB on the floor and that would probably work fine inside but the apron outside would still take a hit. Still kind of leaning toward the v-bars though. I was plowing the edges of our road back the other day and slid right of the road. Not a very steep bank but enough that the tires just spun in the snow. I had to use the loader to walk myself out.
   / Which Tire Chains #4
I just received a set of Duo-Ladder chains from those folks. This is for R4 tires on a JD 4100. I also ordered a set of two link ladder chains for the front tires.
I considered the V-bars but didn't think I really needed that feature. I might be wrong, time will tell. :eek:
The folks at Tirechain.com were very helpful and the chains arrived in three days.
   / Which Tire Chains #5
I bought a set of H pattern w/V bars for the rears and ladder chains for the front on my first tractor (Kubota L3830) from tirechains.com. The chains worked okay, but with R1s I couldn't keep them on top of the lugs no matter how mounted or tensioned them. I have 2 miles of mountainous gravel road to plow and had to resort to pushing snow down the mountain in reverse with my 7 foot rear blade. Otherwise, I was constantly being sucked off the road.
To give my neck and back a break I've upgraded to a bigger tractor, front mounted AnBo snowblade, weighted tires all around, and Trygg flexi chains front and rear. I think you'll find if you're doing serious snow removal you need serious chains designed to stay on top of the lugs, give you good side traction, and last a long time. Be prepared to drop around $1000.00, though.
   / Which Tire Chains #6
I've got the V bars on my 2wd Ferguson TO-35 and they are amazing! I am almost able to plow up hill.
They do chew up concrete so I have to hand shovel the pad infront of my garage.
   / Which Tire Chains #7
WV,
Your driveway sounds exactly like mine -- except I'm in balmy Hampshire county.
I've got a smaller tractor and a 6-foot blade.
I've been using standard ladder chains for at least 30 years. For my present tractor, with R4s (loaded rears), I've got an old set of car chains for the front. For the back, I bought an old set of 4-link ladder truck chains on e-bay for about $30 -- but that was in the summer.
I've always had steep driveways. Over the years I've found that it doesn't take very much to greatly add traction when chains are added to loaded tires.
On my last tractor, I just used front chains, and it did amazingly well, pushing or pulling up the hill.
I found that all chains will really tear up concrete. My former garage had a lot ridges right at the apron where I backed in.
Keep warm.
Knute
   / Which Tire Chains #8
I use the duo chains on ag tires which work fairly well for the cost and they don't tear things up too bad as long as your careful and don't spin the tires. As mentioned in a previous post to really do what you want you're looking at $1000 for a set of diamond pattern logging chains with carbide tips. Lot of chain and looks like a net so the chain doesn't drop between the tire lugs. All depends on how much snow you get and how deep your wallet is!
   / Which Tire Chains #9
I just plowed my drive, R1's for tires, four link chains on the front, as telltale has said they ride down in the lugs and you don't get maximum grip from them. If I had it to do over, at least for Ag tires, I would pay the extra bucks and get the 2 link chains.
   / Which Tire Chains
Thanks for the help everyone, I ended up ordering a set of 2 link ladders from tirechains.com. I'm hoping the 2 link set up will give me better coverage and when combined with loaded tires, better traction. Should be here on Tuesday. I was going to go with the duo's but the guy told me they can't be made for a 15x19.5 tire. Has to do with the spacing of the cross chains.
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2020 Terex RL4 Towable Light Tower (A51691)
2020 Terex RL4...
2018 JOHN DEERE 160G LC EXCAVATOR (A51246)
2018 JOHN DEERE...
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
JOHN DEERE 17P LOT NUMBER 227 (A53084)
JOHN DEERE 17P LOT...
