Which thermostat do I use
   / Which thermostat do I use #1
MA1920
Central MA
Ford 1920
Before it gets really cold I want to flush my coolant and change the thermostat. My year tractor came with a 160* thermostat. New Holland now has 180* and 190* thermostats. Would it be a bad move to go to a hotter thermostat? Thanks
   / Which thermostat do I use #2
it wouldn't be bad in the winter, it will help a great deal in providing better heat for the cab heater!.
   / Which thermostat do I use #4
The higher temp thermostat won't hurt a thing. Just remember your temperature gauge will read a little hotter.
Thanks for the quick replies. I'll move up to one of the hotter 'stats.
Oh, one more thing. Is there anything special about the OEM parts or would an aftermarket compatible thermostat be fine?
   / Which thermostat do I use #7
It is surely an outsourced part to begin with. There is nothing wrong conceptually with an aftermarket thermostat. But not all aftermarket parts are created equally. If the OEM stat was readily available and not much more $ than aftermarket I would use OEM. You may have to get the gasket from NH anyway.
I come across Kumar Bros. replacement parts fairly often. Any comments on their quality?
Thanks for your help Rick, it's always appreciated.:thumbsup:
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A52748)
2024 Ford F-350...
2011 JOHN DEERE 6115D (A52472)
2011 JOHN DEERE...
2020 Steiner 450 Slope Mower (A51573)
2020 Steiner 450...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
