Which stabilizer bar?
/ Which stabilizer bar? #1
petebert
Outside of Ann Arbor
Here's my setup
Lots of attachment options underneath
If you google Ford 3600 stabilizer bar you see a ton of these.
You can buy those individually for $40-60 or they come as a kit with an angled bracket designated LH/RH for around $100. I don't think I need the bracket because the bottom of my axle has all those holes already.
In this guys video he's using one of these bars and I'm guessing drilled a hole in the lift arm. Would using the existing lift arm bolt work? That guy also mentions the importance of the stabilizer bar and lift arm pivot points being lined up. The preexisting holes in my tractor line up vertically but none seem to line up laterally.
Here's one hooked up to the lift arm bolt
And here's one using the angled brackets and a drilled hole in the lift arm.
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
UNUSED 2026 INDUSTRIAS AMERICA HYD TILT TRAILER (A60430)
UNUSED 2026...
New/Unused Landhonor 12V Diesel Pump (A65583)
New/Unused...
Refurbished KBH Tender (A63689)
Refurbished KBH...
2022 EZ-GO ELITE...
