Snow Attachments which snow tool is best.
   / which snow tool is best. #1
majorwager
Veteran Member
western new york
kubota mx 5100 IH 484 ford 1620 lull 844b
Prequalificatios: similar threads have been posted and individual conditions/restrictions are applicable, Acknowledged
Snow blower, plow. Snow pusher. Bucket use is common but very inefficient, gouging, frequent dumping, snow packs and sticks inside.
Snow blower: most efficient in deep snow and drifts but slow. Useful where drainage ditches line the access road/driveway. They eat gravel, wears impeller blades, dents circular housing, hydro top link and/or skid shoes for unpaved surfaces. Better distribution if piles are impractical. Require high RPM, reduced fuel economy, expensive, especially front mount, rear mount a pain, neck, back. Cab use preferred.
Plow: fast, efficient, deep snow requires lateral piling. Sub- 8", fast removal. Rear weight and 4wd necessary. FEL mount allows benching and pile/bank management. Angling requires 3rd function, expensive, small skid shoes rut unfrozen surface. Trip springs = safety
Snow pusher: fast, sub 8 inches, least expensive, push, lift, reverse, lower, push. Repeat. Large skid shoe surface, mine are 3 x 27 x 2. FEL mount, no added hydraulics. Requires wt. + 4wd. 12+ inches = lateral discharge. Side plates prevent close back-bladeing. Rubber edge, w/ 3 uses.
Pusher grades summer gravel uniformly. Outer mounted skid shoes = no ruts in fresh gravel. Good containment within pushing surface = uniform spreading, doubles as a box blade but in front where you also see where tractor is going. Eliminate attachment duplication.
All methods suffer from unfrozen, uneven surfaces. No single method is perfect. I use combo FEL pusher, rear blade with skid shoes, hyd top link.
I have used each method listed. Uniform agreement never anticipated. Personal preference works best. You are NOT clearing my drive, I'm not doing yours, Comments still invited.
   / which snow tool is best. #2
I have a paved drive and a dirt drive I just use the bucket one less attachment to buy and trip over:2cents:
   / which snow tool is best. #3
I have 300' driveway w/good size parking area plus found plow w/rear scraper blade works the best all snow conditions,only down side need keep banks push way back tho.
   / which snow tool is best. #4
The best snow tool is the one that is paid for and does the job for you. I have a 38 yr old tractor with an 80” snowblower that keeps my 600’ lane open no matter how much snow we get. There are other ways that would work too, but this is the best one for me.
   / which snow tool is best. #5
The best snow tool depends on the job to be done. As you pointed out there are many variables. If I had to pick just one I'd go with a front-mounted blower.
   / which snow tool is best. #6
There is a third type of blower-the modern 2-stage rear pull
No turning around to watch it all the time, works great on smaller snows, not so much on deep or drifted. only handle the snow once. Pronovost and maybe others make a hydraulic wheel kit for soft surfaces. Rear pull also puts less snow on you while driving than front mount or rear push. Not cheap, but some of that is because most styles made are either commercial or semi-commercial in construction.
   / which snow tool is best. #7
The best one is the one you haven't gotten yet but are wanting.
Like I'm want and looking for a used inexpensive inverted blower 8 to 9 feet wide, I may be quite a while finding that critter.
   / which snow tool is best. #8
A power angle snow blade on the FEL with GAUGE WHEELS NOT SKID SHOES works wonders. You never have to turn around and watch it, so easy on your back and neck. My little PT425 can stack snow 6' high if needed. While a blower would be nice, we rarely have enough snow to justify the cost. The blade was only $450 when I bought the tractor. There was no added cost for the hydraulics on my machine, as it came equipped standard that way, as ALL of the attachements are on the front end loader.
You could add a third function to your machine with an electric diverter valve for about $300 or less, so that is not much of an expense and well worth the cost for power angle. You could also use the same function to power a grapple, so double the justification.
   / which snow tool is best. #9
This, the method that works for you. If it moves the snow and you can go on with your life, it works. Sometimes we get hung up the tools and forget tool is merely that which gets the job done. I also like Erik's word. "the one that is paid for".
   / which snow tool is best. #10
Boss V Plow mounted on a 3/4 ton truck of your choosing. You can plow in a warm cab and take friends along if you like.
12in Backhoe Bucket (A44789)
12in Backhoe...
2013 Kenworth T400 Truck, VIN # 1NKBH27XXDJ351951 (A44391)
2013 Kenworth T400...
2012 Sun Coast 12ft Enclosed S/A Trailer (A42742)
2012 Sun Coast...
Chery Single Portable Toilet (A44502)
Chery Single...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A43003)
2018 KENWORTH T680...
2017 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A43003)
2017 INTERNATIONAL...
