Which snow blower should I order?
   / Which snow blower should I order? #11
From my user manual. My fan motor 105-1402 is rated at 25 - 31 gpm. This is a SB200 78" on a high flow 5600 toolcat. I use my stump grinder and soil conditioner in high flow from the toolcat also. But I can't use my A300 high flow in high flow. Just standard flow. The A300 high flow is 37 gpm.
Doug O
   / Which snow blower should I order? #12
Fan motor
105-1398 = 12 - 16 gpm
105-1399 = 14.5 - 18 gpm
105-1400 = 16.5 - 21 gpm
105-1401 = 21 - 26 gpm
105-1402 = 25 - 31 gpm
105-1403 = 30 - 38 gpm
   / Which snow blower should I order? #13
As I look at the blower O&M manual schematics, it looks like the controllers between the std flow(SF) and HF are actually the same part (p/n 6678677). I was thinking the HF and SF controllers were different...but it doesn't look so. In comparing the schematics, I see only one difference in wiring when comparing the HF wiring schematic (Page SPEC-5) and the SF schematic (Page SPEC-6). After snow removal season is over, I'd be tempted to simply jumper pins B and A on the OUTPUT side of the controller to see if you automagically get a HF model. That would seem to be one heck of a cheap upgrade if it worked.
It appears that Bobcat may "jumper" (or doesn't) those two pins by use of different VALVE wiring harnesses. The HF p/n is 6734189 while the SF harness is p/n 6734188. This is the VALVE harness, not the 7-pin harness.
Please note that I have NOT tried this myself. So if you try this and the world implodes, don't blame me. ;)
   / Which snow blower should I order? #14
I think the high flow models do have a larger diameter blower fan. I am just spinning the smaller fan faster by holding down my toolcat high flow button. The 7 pin is a digital communications between the attachment and the loader. Its all programing. That is why I must hold down the high flow button. If I remove the 7 pin connector the high flow button will stay on. But then I can't turn the shoot.
I will be taking my A300 in to the dealer soon to have it reprogrammed for high flow. I have changed the pumps and oil cooler for high flow. Plus many other parts.
   / Which snow blower should I order? #15
In my experience, the Toolcat automatically goes into Hi-Flow mode as soon as the 7 pin connector from the SB is attached and when connected to a machine that has hi-flow capability (skid steer or Toolcat). The SB's were available with a high-torque, lower-speed fan motor package that uses all three hoses, and a lower-torque, faster-speed fan motor to throw the snow farther (this setup only uses 2 hoses). They were called the 8.0 and the 9.6 motor package. I have had both and prefer the lower-torque, farther throw motor package. Even though there are tradeoffs, this seems to work better for me. Both units there were SB200-72's.
DEWFPO
   / Which snow blower should I order? #16
Picture of our December snowblowing. Total was 13 to 14 inches.
   / Which snow blower should I order? #17
Another picture
   / Which snow blower should I order? #18
That is really good throwing distance. My machine is a low flow and I got the torque motor so it throws only about 10 feet. Make sure you keep the rotation chain lubed or it will freeze and not rotate.
2004 John Deere HPX Gator Utility Cart (A55851)
2004 John Deere...
UNUSED FUTURE FTHJ6 40' - 6 SECTIONS HEAVY DUTY (A57193)
UNUSED FUTURE...
2015 GMC Terrain (A56859)
2015 GMC Terrain...
DIRT DOG RC105 5' ROTARY MOWER (A57192)
DIRT DOG RC105 5'...
2008 BMW 535xi AWD Sedan (A56859)
2008 BMW 535xi AWD...
Pelican Statue (A55853)
Pelican Statue...
