Which size bush hog?
   / Which size bush hog? #1
firetractor
I was wondering with a John Deere 850...what is the correct size bushhog to use. 4' or 5'. Thanks for you help!
   / Which size bush hog? #2
You should be fine with a five foot bush hog.
   / Which size bush hog? #3
My brother in law has a 750 JD and pulls a 4 foot shredder clipping pastures in road gear with no stalling of motor. Pulls it in 1H in waist high grass and weeds so you should be able to pull a 5 foot or even a 6 foot with the 850.
   / Which size bush hog? #4
Good Mornin Gary,
I think a 6 ft rotary cutter would be a bit much for a 22 PTO HP tractor IMO. Unless its a very light duty mower just the weight alone is going to waggle that JD 850 all over the place. Throw in moderately high grasses or weeds and a slight hill and its all over ! JMO !
   / Which size bush hog? #5
IMHO.. 5' is the happy common ground for a rough cut mower... etc.
soundguy
   / Which size bush hog? #6
5 foot is what i would go with
   / Which size bush hog? #7
Until recently I owned a JD850, had it for about 10 years. Did alot of bushogging with it, a 5' will do just fine.
   / Which size bush hog? #8
The conservative rule of thumb I use is 5 pto HP per foot of cutter.
   / Which size bush hog? #9
I pull a 6 ft with a 39 HP hydrostat and have NO difficulty whatsoever even in waist high or worse stuff. In really challenging situations I slow down some and still there is no problem.
I made a round trip to OKC today and the crews were out in force mowing the grass along the highways (Interstate 40 etc.) I was sort of surprised at how slowly they mow sometimes in what looks to be not especially challenging grass.
If I mowed as slow as they do I would be a longtime getting finished and I could pull a much larger mower than 6 ft.
   / Which size bush hog? #10
A rule of thumb is about 4 PTO hp per foot with a brush hog mower, some say 5hp per foot, it depends if you have slow speed gears to handle the heavy stuff. I have a 51" cut brush hog (55" width) with 16PTO hp and if the brush is too tall I can always drop down a gear, with the old fords N's 1st gear was too high speed is some cases to pull a 5ft. And they were close to 24 PTO HP. I have heard them taking 1/2 swath in heavy grass, ( 2 1/2 FT?)
2012 WESTERN STAR 4900 (A53843)
2012 WESTERN STAR...
RIDGID POWER DRIVE/HAND HELD THREADER (A53843)
RIDGID POWER...
2022 Padget Morris Electric Mobility Scooter (A54815)
2022 Padget Morris...
UNUSED Red Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Red...
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
BENNU HYD SCAFFOLDING SYSTEM (A52706)
BENNU HYD...
