Which rotary cutter? Kubota LX2610
   / Which rotary cutter? Kubota LX2610 #1
JME81
New England
Kubota LX2610HSDC
Rear PTO is 20HP.
I'm looking at two models:
RCR1860 = 10g steel, slip clutch, 2" brush
RCR1260 = 12g steel, slip clutch, 1" brush
I'll be mowing a 4 acre field twice a year. There's some brush, nothing big to remove. I'm not sure which one to go with, I'd like to go with the large cutting diameter, but there's about a $600 difference.
Thoughts?
   / Which rotary cutter? Kubota LX2610 #2
Rear PTO is 20HP.
Thoughts?
If you're at all concerned about the brunch, cut it with loppers or yank it out; it's really a one-time concern as any regrowth is going to be small next year.
IMO the 1260 will handle very occasional 2" brush just fine (I've got one - auction buy $1k). It doesn't like the occasional 5-7" rock, but other than a vocal complaint there hasn't been any repercussions that I can see.
I think if you're mowing brush all day you'd want a heavier duty one, but for mostly field, the light duty is fine.
What about the IronCraft 1205?
   / Which rotary cutter? Kubota LX2610 #4
If you're just mowing a four acre field twice a year, the 1260 should suffice. As you will be knocking it all down frequently enough, it shouldn't grow too thick for the 1260 to handle.
Can't speak to the Ironcraft 1205, but I do have a 1248 myself and it does my fields with mainly grass and some brush when I want it to.
45015 (A48082)
45015 (A48082)
Diesel Pump , Hose and Handle With Reader and Spool (A46684)
Diesel Pump , Hose...
Bush Hog Ditch Bank Mower (A49251)
Bush Hog Ditch...
Golf Cart (A48082)
Golf Cart (A48082)
2015 Dodge Charger Sedan (A46684)
2015 Dodge Charger...
Perfecto 6ft Harrow (A49251)
Perfecto 6ft...
