Which recovery D Ring to weld on?
   / Which recovery D Ring to weld on? #11
I like to have several options available to hook to. A clevis attachment point for using an "eye" in a cable, rope or strap along with a chain grab hook or "box" is handy for length adjustment.
   / Which recovery D Ring to weld on? #13
I have no idea who sells them but I just made some for my logging winch that I am building. I took some .250 wall x 2" square tube and drilled a 5/16 hole then cut each side with the plasma cutter then welded them on.
To the OP, you can buy the type you have in your second pic that are longer and go through the bumper so you can weld front and back of them. I guess it boils down to your welds for strength.
I bought these when I built a winch bumper for a Grand Cherokee Bumper Clevis - RuffStuff Specialties
I have no affiliation with the co, but they are great to deal with.
   / Which recovery D Ring to weld on? #14
I would think the first type of ring would make a sturdier weld job, but then if you got situation when a hook couldn't go through you would be screwed.
But, I would weld those on and make sure I carried a removable clevis around with me at all times for those situations.
   / Which recovery D Ring to weld on? #15
Found these D Ring mounts for clevis style. Little more money, but looks like it wrapping around the top or bottom edge of the bumper would add alot of strength to it. Opinions?
I would use them ,one or two?
   / Which recovery D Ring to weld on? #16
   / Which recovery D Ring to weld on? #17
This idea may not be something that interests you but, thought I'd offer it up.
I like versatility. I like it in just about everything I build. So, I would suggest that you weld/bolt on a receiver hitch (similar to what's on the back of most pickups) onto your mounting surface and then have the same capability for getting pulled out of sticky situations and have the ability to put a ball hitch on the front of your tractor. A receiver hitch will also have points where trailer safety chains are normally attached that can be used as additional tow points.
I've done this with my Ford and use it to push/pull bumper pull trailers around when needed and have used it as a point to tie onto the few times I got stuck. It frequently serves as a point to tie a chain/cable onto so I can drag something to a different location. Allows me to have a frame mounted point on both front and rear of the tractor. It also provide me with an additional tie down point for when I transport the tractor. And, the male part pulls out for when it might be in the way of some other attachment that would mount up front.
Works for me, might work for you.
Rams
   / Which recovery D Ring to weld on? #19
Great Minds think alike............. :drink:
But then, so do morons, I'm told. :cool2:
Honestly, I've been doing this for a long time to just about every tractor I've owned. It works and is versatile. You won't regret it. Just make sure it's frame mounted and the receiver hitch doesn't interfere with any other attachments that you might want to use in that proximity. :thumbsup:
Rams
   / Which recovery D Ring to weld on? #20
I use the weld on D ring on everything. They're cheap enough that you can afford to. Those shackles and weld mounts get expensive really quick. The 3/8" size is big enough to pass a 3/8" chain hook through so you don't need a shackle.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
JOHN DEERE 772GP MOTOR GRADER (A58214)
JOHN DEERE 772GP...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A55973)
2012 Chevrolet...
2021 CTS T/A End Dump Trailer (A55973)
2021 CTS T/A End...
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
