which portable generators do people have
   / which portable generators do people have #451
The furnace would be number one, then the refrigerator, hopefully there would be enough left to run the internet and or tv. I want to get the six circuit transfer switch that way I can cycle things if I need to. I also like the option that I can purchase a second generator and parallel it to run more circuits. We have a gas stove, so would not worry about the microwave.
I know my well would not be an option as it runs on 240 volts and the generator I am purchasing only puts out 120 volts. Since we moved here a little over a year ago the power has been out 3 times; once for about 3 hours, 6 hours and 8 hours. The 8 hour outage it was 35* below and the house got down to about 48* before the power came back on.
Talking to a co-worker that lives in the area, he said they were without power for a week after a storm two years ago.
I have a food grade 55 gallon drum for water storage that I could use for flushing the toilet, washing dishes etc. We also keep some bottled water on hand.
This is basically my current setup. 6 pole transfer switch(I'm not using the 220 as my gen is 110 inverter) with a 3600w gen. I can run my furnace (oil burner with 4 zone pumps), refer, full size freezer, all the ceiling lights, network gear plus I have a couple plugs in the kitchen. I can plug my micro or whatever in those. With everything but the micro running it's just a bit above idle except it blips up when a compressor starts on the two appliances. The micro will pull a bunch of power but we did make much of Thanksgiving dinner on it one year. We shut the refer & fridge off for that. Tried to run a griddle at the same time, that was too much.
   / which portable generators do people have #452
That is good to hear. The generator should be in tomorrow so I will pick it up after work. I will not have a chance to fire it up for a week or two as I am having carpel tunnel and elbow (allmer?) surgery done. I had my right hand / elbow done last year. I need to try to get all this stuff done before I retire in two years. Might look at having my shoulder done next year.
   / which portable generators do people have #455
A lot depends on the ambient temperature. I used to do a food booth at a craft fair. We found a wonderful 6' cast iron griddle, and found that a 20 lb. tank would not provide enough gas, so bought a 100 lb. tank. There was no room for a 100 lb. tank under the grill, so we dug a hole and set the tank in the hole. Of course, it iced up. When we dug the tank out it, the dirt around it was a solid block of ice. Keep a heater on that little 20 lb. tank and it will work fine. Otherwise, the propane cools by evaporative cooling until it won't evaporate any more. A larger tank has more surface area, so the propane stays warmer, but if you plan on running a propane generator in sub-zero weather, some means of heating the tank is a good ideal. A system that tests fine in the middle of the summer may starve and die at 10 below.
This never happends to me, and it gets down to -30 or more in the winter.
   / which portable generators do people have #457
Well, it wasn't to buy a generator! lol lol
SR
Here’s the generator you mention was returned. Hundreds of positive reviews.
I find it interesting you were in the store, though, this tempers some of your other comments about quality tools.
875 Max Starting/7 Running Watts, 13 HP (42cc) Generator EPA III with GFCI Outlet Protection
If someone is running regularly for hours a week, I’m sure a $4,000 fuel injected Honda makes sense. That $600 noisy, thirsty HF unit will keep the lights on.
   / which portable generators do people have #458
Yep it depends on what you need. Bought my gen from Costco. 6700 watts with I think 8k surge. Probably sucks a little under a gallon an hour. With some load management I can run the house on it. Just need to make sure the boiler pumps and well pump don稚 kick on at the same time. Easy enough to do.
   / which portable generators do people have #459
I keep seeing people running barely large enough generators right to the edge of tripping, instead of leaving some margin for motor starting and generator reliability . A consumer grade generator is not really built to operate continuous at "max rated" amperage.
Your generator and your electrical loads will last longer if the generator has power to spare instead of lugging the genny's guts out.
I also see people with little four, six or eight circuit transfer panels ??? It doesn't very much to install a interlock slider on a breaker panel. That way all the lights and receptacles will work on the generator. Just open the breakers to the electric stove and electric clothes dryer to prevent overloading the generator .
For the cost of the re-wiring and installation of a little 4,6 or 8 circuit transfer panel. When the FPE Stab-Loc panel had the main breaker failed. I just swapped in an entire 200 amp panel with a built in transfer switch. 18 circuits on the generator side so all lights, receptacles and well pump operates. Also installed the 100amp version in the daughter's house. There was a jackleg installed FPE Stab-Loc and a pony panel in the utility room there. The cut and past of the individual page did not format very well . Here is the link and look on page DE1-8 for the "All in One" https://www.schneider-electric.ca/d...istribution/en/shared/catalogue/DE1.pdfNumber
Loadcentre Catalogue Number https://www.schneider-electric.ca/documents/electrical-distribution/en/shared/catalogue/DE1.pdfTrim
Catalogue Number
Main Wire Size Al or Cu (AWG/MCM)
Standard QO
Tandem QO
3▼
QO403L100S 
Included
12-1 Al or 14-1 Cu
12▼
24
QO312ML1
QOC16UC
4 - 2/0
20▼
40
QO320ML1
QOC24UC
4 - 2/0
24▼
48
QO324ML2
QOC30UC
4 - 250
30▼
60
QO330ML2
QOC30UC
4 - 250
42▼
60
QO342ML2
QOC42UC
4 - 300
Total Number of Circuits
Number of circuits available for (generator) critical loads
Standard QO
Tandem QO
Standard QO
Tandem QO
4
8
CQO48M30DSGP
#14-8
4
8
CQO48M60DSGP
#8-2
18
36
QOGP3P3036
#14-8
18
36
QOGP3P6036
#8-2
40
80
18
36
QOGP3P604436200
#4-250
40
80
18
36
QOGP3P604436150
#4-250
40
80
18
36
QOGP3P604436125
#4-250
40
80
18
36
QOGP3P604436100
#4-250
QOョ Loadcentres and Circuit Breakers
QOョ Main Lugs Loadcentres - Type 1 Indoor
QOョ Main Lugs Loadcentres (1リ - 3W)
Mains Ampere Rating
30 70
100
125
200 225
QOョ Main Lugs Loadcentres (3リ - 4W)
Mains Ampere Rating
100 125 125
200 225
QOョ Generator Panel (1リ - 3W)
Mains Ampere Rating
Box Size (see page 16) 1
2
3
4
4
4
6
7
8
9
11
11
11
12
14
5 7 8 10 10 12
30 4 60 4 30 6 60 6
QOョ 疎ll-in-one SE Generator Panels
200 150 125 100
 Service entrance approved.
● Will not accept QO-GFI or QO-EPD breakers.
✚ Maximum 20A QO-GFI breaker or AFI breaker.
▲ Maximum 70A branch breaker.
◆ Does not include a door. Order kit # QODK60-2.
▼ Shunt trip feature not available on any 3リ loadcentres.
12 12 12 12
   / which portable generators do people have #460
Generac 22kW propane for whole house.
If I go easy on my electricity usage, my propane tank will last me about a month.
2014 10ft T/A Dump Trailer (A51691)
2014 10ft T/A Dump...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
Texaco Vintage Decorative Fuel Pump (A55758)
Texaco Vintage...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
UNUSED 70PCS Black Metal Roof Panels (A53117)
UNUSED 70PCS Black...
Butterfly Artwork (A55758)
Butterfly Artwork...
