which portable generators do people have
   / which portable generators do people have #291
for those of you actually interested in using an inverter, they now make hybrid inverters, that have "generator support", how it works is, when a large load comes on, and the generator dips, the inverter is in passthrough mode. once its see's the dip, the inverter goes into inverter mode and assists the generator via its battery's to power through the surge to allow a smaller generator to power bigger surge loads, i have primary seen them installed in RV's. these inverters also charge the batterys back up at the same time.
be aware these type of inverters are not that cheap
   / which portable generators do people have #292
The Utility vehicle/power source seems like a good idea. But like I said, I like a compartmentalized approach. Probably they would have a microprocessor run the whole thing, and when you needed it, nothing would work!
I just came across this LaiDong "Compressor" on E-Bay out of Canada. They also sell the Listeroid "Compressors". LOOK MA! 2018 and NO PLASTIC! Anybody know anything about these? I see from You Tube that they run at 2200 RPM! That's disappointing.
I also see many 48 Volt Turbine Generator Ends, but they are pricey!
   / which portable generators do people have #293
Here's a working model:)
   / which portable generators do people have #294
I am one of those that has had a giant (250gal+) saltwater reef tank that needs constant power for lights, heater, water circulation and filtration pumps, etc. to keep the coral and fish alive.
Cool. Pictures?
   / which portable generators do people have #295
I just saw this awesome genset sell on E-Bay. Was sitting at a grand and sold for 3 grand. 500 something hours, 2 cylinder Diesel, (1800RPM) Air cooled. 5-6 KW, Single or 3 Phase. NEVER seen one like it. Three fuel pumps. Had it's own tank, or you could pump out of a 55 gallon drum.
Now, THAT is a portable generator! Might still be a tad noisy though for being air cooled.
I was tempted but not for 3 grand. Curious if anybody ever had bad experience buying used military gensets. Everything looks so unfamiliar.
   / which portable generators do people have #296
Cool. Pictures?
Sure... thousands. Don't want to hijack this thread but here are a couple of pics from my giant reef tanks... both over 250gal. SPS, LPS, fish, clams, crabs, etc... having backup power is critical!
unsorted 201.jpg IMG_2389.jpg IMG_5450.jpg IMG_5497.jpg IMG_5374.jpg unsorted 031.jpg
   / which portable generators do people have #297
Aren't nature's colors the best?
   / which portable generators do people have #298
WOW! SO COOL! Sorry, back to the thread subject.
   / which portable generators do people have #299
It's not a hijack... more of an interlude...
Now back to our regular programming...
   / which portable generators do people have #300
Agreed, relatively speaking, but not usually the first concern in an emergency. For extended use, generator noise gets old quick though.
I was just yammering on about good rural solutions I've seen for Ram's issue, heat, and being mindful of what he has in place already.
Kentucky Electricity Rates | Electricity Local
KY rates are not what I'd call low, but as their Winters are probably mild by Canuck standards, I can see electric baseboards being common.
A small modern suitcase gen is pretty quiet, and definitely way quieter than any tractor I'm familiar with - Ram's option listed was going PTO.
We have many options available today - That's why it's fun to play Fantasy Power System Designer, on a cold Winter day :)
I'm definitely a fanboy of inverters+batteries, so that's what I have in place for light loads here.
If selecting a new pellet stove, I'd be looking for one that runs on 12vdc, so may not even need an inverter for that application. For off-grid/alternative systems, direct 12vdc operation is something I'd be looking for in most applicances.
Rgds, D.
As I previously stated, I was looking to upgrade from an Onan I currently have. Was hoping to power the whole house but, it appears I don't have sufficient tractor horsepower to do that so, I'll stick with what I've got. BTW, compared to where Dave is, my heat requirements are insignificant.
Spent way more time in cold country while I was in the military that I do not wish to repeat, not my idea of a good time. If that's what you like, I'm all for you but, it's not for me. KY is just about right. Have all four seasons and they are all about 3 months long. I like it that way.
The house is all electric. We have a propane fireplace, won't be adding a pellet, wood or coal option to it. My fireplace is a fake, doesn't even have a chimney. So, the previously mentioned heat sources are not an option.
Rams :drink:
New/Unused 200lbs Cast Iron Anvil (A54865)
New/Unused 200lbs...
2018 Wacker Neuson RTSC3 Trench Compactor (A54865)
2018 Wacker Neuson...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
2025 MAMMOTH SB-2 2025 SAND BOX TRAILER (A56129)
2025 MAMMOTH SB-2...
2011 26PS PROWLER 5TH WHEEL RV (A55745)
2011 26PS PROWLER...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
