Which Pallet Forks for Tractor
   / Which Pallet Forks for Tractor #1
monteu
Bronze Member
NE Kansas
Kioti DK5010
Kiotio DK5010 is the tractor. I've been warned on here before that I can't lift much with a tractor, and I believe that. I regularly unload steel trucks and often it's just light stuff. I'd like a set of pallet forks for when there's too much snow on driveway. Since I cannot lift much with a tractor anyway do I need heavy duty pallet forks? What about these cheap ones on Amazon?
https://www.amazon.com/gp/slredirec...1513901&id=6803601500150854&widgetName=sp_atf
   / Which Pallet Forks for Tractor #2
Non adjustable forks would be an instant deal breaker for me. 4000 lb forks are commonly paired with tractors that size.
   / Which Pallet Forks for Tractor #4
   / Which Pallet Forks for Tractor #5
It won’t lift nearly as much as the SSQA forks and the visibility sucks.
Wasn't my point, my Terramite won't lift as much as the clamp ones are rated for either. The point is many buckets are not made very strong and will bend under even the lighter load, because the load is placed far out on the end of the bucket.
   / Which Pallet Forks for Tractor #6
The point is forks clamped on a bucket edge will lift less than forks on a SSQA coupler attached to the same tractor.
And clamp on forks generally have less visibility than direct coupled forks.
   / Which Pallet Forks for Tractor #7
Yes and no
Agree clamp has less vis, and due to being further out, bucket curl will be less
Don't agree it will lift less, vertical weight is vertical weight
In any case, the OP was asking for thoughts/comments, we all get to post those things
   / Which Pallet Forks for Tractor #8
Yes and no
Center of mass is further from the curl pivot and further from the lift pivot with clamp on forks. Both curl and lift paths are radial, not vertical. Disagreeing does not change it.
   / Which Pallet Forks for Tractor #9
Yes and no
That would be true in a forklift mast but definitely not on a tractor loader.
   / Which Pallet Forks for Tractor #10
It still isn’t true for a forklift. While it might not make any difference to the hydraulics it will make a big difference on tipping the machine forward.
2004 PETERBILT 385 (A52472)
2004 PETERBILT 385...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
New Holland B95 Backhoe (A50490)
New Holland B95...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A52748)
2014 Yale 3 stage...
2019 RBR Venturi 380 (A52748)
2019 RBR Venturi...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
