Which one? GR2120 or BX1870
   / Which one? GR2120 or BX1870 #11
I had the same issue come up about 2 years ago that you are going thru now. I had a JD LX188 that needed replacing, so it was GR2120 or BX1860. I ended up getting GR2120 with snowblower, has been a great machine, pleasure to operate. My decision may have been a little easier because I also have a L3940 with fel and front blade. Philip.
   / Which one? GR2120 or BX1870 #12
Hi 70cst. It sounds like we have similar yards; mine is one acre, sloped, and several trees to mow around. I have a G1900 and recently acquired a BX1860. I haven't used a GR, but my G1900 is similar except it doesn't have 4wd. The BX does mow nicely and would be perfectly fine as a primary mower. It is heavier and a little more "tipsy," but unless you have very steep hills to mow I think it would be just fine.
If you only plan to mow and maybe move snow I would go with the GR. However, if you think you might want to do any implement work (who can't think of a list of projects for a front end loader?!) the BX will mow basically just as good while still being able to accommodate implements.
For what it's worth, I planned to sell the G1900 and use the BX but am now thinking I will keep both. I could do it all with the BX, but I really like zipping around quickly on the G1900. Still, if I had to commit to only one machine it would be the BX hands-down.
Thanks fir your input 👍
Yes it sounds as if we have similar yards -- I'm leaning towards the BX1870 👍
   / Which one? GR2120 or BX1870 #15
Go with the BX. Our BX2660 (with turfs on) won't tear things up unless you crank the wheel all the way over.
The GR series had some issues for a while with transmissions that didn't hold up.
Aaron Z
   / Which one? GR2120 or BX1870 #16
The advantage of the BX is the 3 pt hitch, rear pto, and the ability to add a front loader if you want to later.
   / Which one? GR2120 or BX1870 #17
I bought a new GR2120 in early 2015. I ended up returning it because it could not go up a couple of my slopes, which I found I absurd for a 4wd.
I took it back the same day and brought home a BX. Couldn't be happier.
I read about the GR HST issues in the past, but hoped they were resolved. I was wrong. My 2wd Home Depot special HST that I was replacing would pull steeper hills than the GR. The HD would lose traction, but would never "give up" like the GR.
The BX of course is a great machine.
   / Which one? GR2120 or BX1870 #18
rj,
That really surprises me. My GR will go up any slope that won't make it fall over backward. That's one of the things that I really like about it. Very strange.
Z.
Well I pulled the trigger ... I purchased the BX1870. The Price difference was only $500 between a GR and a BX. I paid $10,500 for the BX1870, 54" Deck with a 3 Bag Bagger. I was hoping to buy used but after looking about a month nothing came up that peaked my interest. The GR2120 is a nice mower but long term I thought the BX better met my needs. I appreciate all your thoughts and replies. Thanks
   / Which one? GR2120 or BX1870 #20
You are getting good advice I think based on what I am hearing from you. Since you say you are not expecting a manicured yard and if you want to play in the woods, do any other kind of landscaping, gravel, dirt, bark, the BX is the right machine. I love mine but I don't mow with it. I have a small Zero turn. Best of both worlds.
New/Unused 250 PVC Safety Traffic Cones (A51573)
New/Unused 250 PVC...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 72,061 Plate: Body Type: 4 (A51694)
Year: 2012 Make...
New/Unused AGT YSRT14 Mini Skid Steer Loader (A51573)
New/Unused AGT...
2021 John Deere 9420R Tractor (A53342)
2021 John Deere...
