Rear Finish Mower Which mower would best suit my tractor?
   / Which mower would best suit my tractor? #1
j7o7h7n7
Kubota L275
Hey guys. Need some help in picking out a rear finish mower for my Kubota L275. It has a PTO of 23hp. I am moving to a house with a much larger yard than I currently have been mowing. I will be mowing 3 acres every week. It is level gound without trees. I would like a 6' mower but I'm concerned if my tractor can handle it. This will be my first purchase for this type of attachment. I do not know which brands to avoid, or which ones to pursue. I live in Vilonia, AR 72173. Any advice would be appreciated?
John
   / Which mower would best suit my tractor? #2
If you mow every week, you may get by with a 6 ft. The best choice may be a 5 ft. We have the First Choice and Phoenix (both made by Sicma in Italy) You can'[t buy a better finish mower. 5 Ft $1395, 6 ft $1895. Anti Scalp wheel is optional and cost $100. Ken Sweet
   / Which mower would best suit my tractor? #3
With a level lawn and mowing weekly, I'd go with a 6' mower. I had a 5' mower behind my 24 PTO HP Deere 790 and it could have easily ran a 6 footer.
So now, it's just a matter of how much you want to spend. RFMs aren't cheap...and they get more expensive the bigger you go.
I have experience with Befco...great mower, but not the least expensive. Had two (that 5' unit and my current 7' mower)...both have provided outstanding service.
   / Which mower would best suit my tractor? #4
Ken sold me mine. I'd highly recommend that RFM. I know Kioti liked it enough to put a decal on it and make it their mower.
That the color pretty much matches your 'Bota is a freebie.
   / Which mower would best suit my tractor? #5
Ken is right on. I do have a Woods 72" that I run behind my B3200 which has just a little more HP then yours. I cut about the same 3 acres and the tractor is hardley working, you should be good for either the 5' or the 6', but as you said no trees==6 ', go for it.
DevilDog
   / Which mower would best suit my tractor? #6
You should be fine with a six foot finish mower
I had a JD 4200 (21.5 pto hp) with a 6 foot mmm, that I used for seven years to mow 3 acres with some 25 degree inclines. Never had any power issues but did occasionally have some traction issues.
   / Which mower would best suit my tractor? #7
Did you look at a King Kutter RFM-72? It's made in America too... so that's a plus. You might check it out.
This is a picture of a 5' model, but the 6' model looks the same, just wider.
   / Which mower would best suit my tractor? #8
If was going to buy a new finish mower, it would either be a Landpride, Bush Hog, Woods, or a Phoenix (made by Sicma in Italy). Any of these are the best brands on the market today. I personally like the Landpride finish mower best. But prefer the Bush Hog rotary cutter over any other brand out there.
I don't need a finish mower because I have a zero turn mower. I'd like to buy a used finish mower one day just so I'll have a "option" to choose what I'd like to cut the grass with "this time." So, if I ever buy a finish mower, I'll search for a used mower that may need a little work done to it.
   / Which mower would best suit my tractor? #9
Why do you write "Any of these are the best..."? Do you have personal experience in using all of those brands? Or any (since you use a zero turn mower)?
   / Which mower would best suit my tractor? #10
I agree with travis R. I have a MF 1040 and a Woods 72" finish mower. works great. I mow 3 acres. But, I also have a Kubota ZD 21 60" mower and I used the finish mower 3 yrs ago just to play with the tractor. If you want to mow and get the job done, the z Turn will do 3 acres in about 1.5hr...lot more time with the tractor and still have to trim. Anyone need a used only 4 times almost new woods finish mower? The finish mower is nice to have in a emergency but if want to mow and GET Done , then a z turn is way to go!!
2008 Chevrolet Express 3500 Passenger Van (A55852)
2008 Chevrolet...
2017 Takeuchi TL8R2 Compact Track Loader Skid Steer (A55851)
2017 Takeuchi...
UNUSED FUTURE SE61-61" HYD SWEEPER (A57193)
UNUSED FUTURE...
RIGGING BOX W/ MISC SHACKLES, LIFTING CHAINS (A54757)
RIGGING BOX W/...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A53485)
THIS WILL BE A...
2009 Ford F150 (A55973)
2009 Ford F150...
