which motor package for sb200
   / which motor package for sb200 #11
SP6x6,
I'm not sure what tactic Spudgunner uses but when we are faced with a burm that is 3 to 6 feet we start by raising the blower box and eating off the top until we are down to pavement. Once a blower wide section has been opened you can then take smaller ( 1/2 to 1/3 the width of the box) bites without much difficulty. The other thing we do is open the width as we go instead of blowing the entire length first. This way if you plug the blower or have a mechanical issue you can actually open the door and get out of the TC versus being "trapped" by the narrow (blower box width) area you opened.
   / which motor package for sb200 #12
Timm9, That is my technique now, it is just that the dealer lead me to believe the SB240 would work. I have worked side by side w/s250 ,7' SB240& SBX 240 AND they seriously launch the snow. They can walk threw 3' no chains easy, hi flowtoo.
   / which motor package for sb200 #13
Spud gunner, The offical site for Bobcat also shows a SB240 on a tool cat. What is the solution for 3' type drifted snow? It seems like the Toolcat is more user friendly for snow removal than a SS. Better visability,comfort, less cab noise and speed.Also less weight to haul to the job than a large frame SS.
To each their own, I'm just mentioning what my sales guy said about the larger blowers. In fact he initially objected to the 72" SB200 and would only spec one out after I insisted. After using a SB200, I would not opt for the larger blower because it's my opinion that the SB200 (I have the 72" model) is all my TC can handle from a hydraulic standpoint for my conditions....and to a lesser degree weight (check out the boom config on a TC vs SS.) Remember that your blower will become packed with snow which will add weight as well. But it's the hydraulics that seem to be the real limitation to me. There are folks here who use the 240...you might search for their posts.
After using the SB200 and then seeing the snow removal vids on the BC website, I don't give much weight to what I see on their site. YMMV.
In the TC vs. SS debate, you're absolutely right about visibility, sound, comfort. Weight doesn't seem like a big deal because I think you'll find that you'll like ballasting a TC. Speed IS a big deal. With the ability to go at least 18MPH, you may find you use your trailer lots less. On the other hand, there's a guy about 50 miles north of me that traded his TC for a S250 HF and he couldn't be happier. He's into moving big quantities of snow and likes to throw it a long way. I believe he has a 240.
IIRC, it sounds like your sales guy will demo the equipment for you. Can't get much better than that! If I was rich I'd get both a TC and S250/S300 class machine. Woot! Good luck with your purchase, whichever machine you get.
   / which motor package for sb200 #14
I agree. There is no free lunch...and no free horsepower. A bigger blower will work until you get to a real load...and then it will be like peddling uphill three gears too high. You'll smoke your hydie oil and still not turn the bigger load at the right speed.
   / which motor package for sb200 #15
When the mechanic was out last week he forgot to bring his pressure gauge setup to check my output pressures (duh!). He said that I have the correct motor (1464) for this machine (High Flow TC) and snowblower (SB200-72) based on their past experiences. He thought this fan motor was rated at ~40GPM. He said they have previously gone with smaller, higher speed motors and they threw the snow further but they got very hot in the process and lugged the engine down when blowing heavy or deep snow. He said they prefer to spec this motor (1464) to provide better motor longevity and less engine pulldown. He said since the motor can handle ~40 gpm you have to run the Toolcat at full power all the time when you are snowblowing to get any throw out of it since even with the high flow option on the TC you are putting out <30 gpm. I have not been able to get the actual specs on this motor from the manufacturer to verify this information.
DEWFPO
   / which motor package for sb200 #16
DEWFPO,
You have the exact same SB200 setup as I. As usual, here's some good news and bad news...
First, the good.... Following is a link to the PDF covering Char-Lynn's (Eaton) hyd motors:
http://hydraulics.eaton.com/products/pdfs/E-MOLO-MC001-E5.pdf
The 105 prefix on our fan motor p/n appears to designate it as a Series 2000. Specifically, I believe it is a Series 2000 Wheel Motor as shown on pg. 21 of this PDF. And...I think the displacement is 8.0 cu. in. as my sales order specifies an "8.0" motor and Char-Lynn just happens to have an 8.0 motor. This is an inference on my part that may not pan-out.
The bad news... the 1464 isn't listed in the above document. I've read elsewhere that this is an OEM-only motor...which may explain the omission. Seems strange to me, but there is no 105-1464 motor that I could find listed. The 1464 motor also appears to have the "manifold" mounting style as shown on pg. 27. The table showing p/n's is on pg. 29. Note that 105-xxxx motors are all "wheel motors" in that matrix.
Big question for me: What's the hyd flow limits on this motor? Based on the above document, it looks to me like Series 2000 motors should run in the range of 20-30 GPM.
It would be interesting to know what the guys with heavy, hi-flow SS's (e.g. S250) are using for blowers. I'd be a little reluctant to run my SB200 on such a SS with hi-flow turned-on given the specs for the Series 2000 motors.
   / which motor package for sb200 #17
My buddy runs a A300 SS with a SBX240 x 84, it supposedly takes 35-42 GPM . When the snow is heavy he wishes he had a 100 hp machine. He is full comm. at the ski area
   / which motor package for sb200 #18
DEWFPO,
Thanks for the info Spudgunner. I too have been trying to research info on the 105-1464 but it is nonexistent and e-mails to Eaton/Char-Lynn and others have gone unanswered.
There are a few here that apparently have the 9.6 motor pkg. I wonder what fan motor (P/N) they have.
DEWFPO
   / which motor package for sb200 #19
I'd like to see that run! When visiting my BC dealer last week they had several S250-S300 machines with SBX blowers attached sitting in service bays. I didn't think to look at the part numbers on the fan motors. My wild guess is that they are Series 4000 Char-Lynn motors. Note: "Wild Guess". I'll be visiting my dealer in Boise sometime in the next couple of weeks to discuss this subject as I'm possibly in the market for a S205 or S250. Hi-flow on the 205 would work perfectly with the blowers I have (BC SB-200 and Erskine/QA ES2000) while a 250 might not due to it's hi-flow numbers (37 GPM). About the last thing I want to do is buy a new blower what with having two sitting down in my barn at this point.
2025 Swict 84in Bucket Skid Steer Attachment (A55851)
2025 Swict 84in...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
SEET BOX W/ CABLE SLINGS (A54757)
SEET BOX W/ CABLE...
UNUSED FUTURE X.PG44 44" HYD PLATE GRABBER (A57193)
UNUSED FUTURE...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
