Which model?
   / Which model? #1
momark54
Arnold, MO
'63 Ford 4000
Hi guys, I'm planning on getting a new tractor soon and was wondering what you all think would be the minimum size Kubota I would need to operate a 6' three-point tiller that weighs around 800lbs without a strain on the machine? Would also be using a 5' brushhog. Thanks in advance.
Mark
   / Which model? #2
The only help I can give is my old BX2200 handles a 5' tiller with ease breaking sod. I have to go a little slower on dry sod but still gets it done.
I have 16hp at the PTO.
I would opt for closer to 20hp at the PTO for a larger tiller.
   / Which model?
Thanks for the response. Do you know what your lift capacity is on the 3 pt. hydraulics?
   / Which model? #4
Mine is 1260lbs at the lift point and around 640 24" behind.
Have you looked at the BX25D?
   / Which model? #5
I've used a 72" tiller with my L4610 (46 engine hp, 40 pto hp) for many years. The tractor basically doesn't know the tiller is back there, even operating at less than full pto speed. The key is that tilling involves slow movement in order for the tines to break the ground into ever finer consistency. I would think a mid-30's hp tractor should have the power to drive a 6 ft. tiller. Then the question turns to having enough tractor size and weight to handle an 800 lb tiller attachment. Obviously more tractor is better than not enough, so that's easy work for a Grand L and the standard L's should be OK as well. You can find a B sized tractor with the hp to run such a tiller but it's probably going to get tossed around a fair amount as the tiller digs.
   / Which model? #6
I think my tiller is 66" (King Kutter) & it puts a hurt on my 32hp L3200. The HST means I can trivially adjust my ground speed to max load possible on my engine without lugging it. It would be a lot harder with a gear tractor & may not even be possible if it wasn't geared low enough.
All in all my tiller is a good match for my tractor. I could use more power to run it & go faster than the crawl I have to go at, but its fine for the occasional tilling I need to do.
   / Which model? #7
How fast do you want to go? You say minimum size, is this to keep the cost down? I'd think you could run a 6' tiller with an L2501 if you weren't in a hurry and it was a hydrostatic machine. I think that'd be about the cheapest option new, but I could be wrong. I don't know much about the B series. I wouldn't personally consider a BX. In all the Kubota series, there are premium and economy models. It's usually possible to get more weight and more HP for less money with an economy model, but the premium tractors do have nice features. Tell us about your budget and size constraints, do you need a small tractor to fit somewhere tight, but want maximum horsepower, or do you want something cheap that'll do the job a bit slower?
   / Which model? #8
I think the type of soil you have plays a large part in the hp required and whether you are in drought or not. My 21 hp B7510 struggled immensely one year when we were in drought with a 48" tiller. I had to weight the tiller down with several 50 lb bags to keep it from bouncing. Would be a totally different story in sandy or loamy soil. At any rate your old Ford 4000 has about 46 pto hp according to tractordata.com. A new Kubota equivalent would be an L40 somehting or other. Depending on soil type I would not hesitate to put it behind my L39 with HST. Would not put it behind my 7510 or B3200. I would be afraid of damaging the PTO drive.
   / Which model?
My main use for the tiller would be for foodplotting. Normally I think I would only like to till to a depth of 2-3", just enough to grind up any vegetation and get good seed to soil contact. I would brush hog as low as possible before tilling. I know the 5speed 4000 is probably a little fast for a tiller but I'm hoping it might work ok at that shallow of a depth. If it flat out doesn't work I'll probably end up getting the Kubota(or something comparable). Just want to make sure I get enough tractor for the 6' tiller while not overspending.
   / Which model? #10
If you are just food plotting & going shallow, a disk harrow might be better. Half the price & will bounce over roots & rocks better.
1973 JEEP RENEGADE (A51247)
1973 JEEP RENEGADE...
2024 40 ft. High Cube Shipping Container (A53117)
2024 40 ft. High...
Concrete Mixer Mini Skid Steer Attachment (A51691)
Concrete Mixer...
2009 Lincoln MKS Sedan (A51694)
2009 Lincoln MKS...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
