which model
   / which model #1
reeltime
East Freetown ma
2014 mahindra 3016 shuttle loader and backhoe with thumb
i have owned 3 kubotas in the past 20 years. I would like to try a Mahindra this time around looking at 26xltlb and the 3016 tlb.We just bought a new place with 5 acers lost of falling stone walls that needs rebuilding rocks from 1lb to 1000lbs want to use backhoe with thumb to stack also stumping pine stump drainage work and grading. So which one and why thanks
   / which model #2
Not sure about the other model, but the 3016 is a rock solid reliable workhorse from all I've seen (know two people with them and they work them hard) and all I've read.
   / which model #3
The 3016 is "last years model"....or should I say being phased out....The new 15 series is comparable with 3016....The 15's look a little bigger and have the tier 4 engines....
   / which model #4
you may find the 26 a little small for your needs. The 3016 would be better suited, size wise....if you can find one. The 15 series replaces the 3016 but with more HP and more $.
   / which model #5
Even though the Max26 and the 3016 spec out fairly close, the 3016 is quite a bit bigger and handles max loads with less drama. Also more lift height and the backhoe is noticeably bigger/stronger. For your tasks, I'd go with the 3016. There are a few left in stock here and there. I think I had about 100 last fall and have retailed all but a handful. The 1533 is a sweet machine, but as a Tier IV you will pay $3k or so more for it. It is a little longer, a little heavier and has some nice features, so you are not just paying a "Tier IV penalty", you are getting more tractor at the same time.
   / which model
Where are you located with the 3016 thanks
Sent from my iPhone using TractorByNet
   / which model
Just saw your Fran CA a bit far any dealers in ma with any 3016 on your lot thanks
   / which model #8
You local dealer can do a search on his dealer portal, or call his Mahindra rep to see if any are available in his region.
   / which model
Just talk to my dealer no luck in finding one in this area which is in ma .I ask if he could ask his rep and and said he can't help .
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
2012 FORD F-550 SUPER DUTY (A58214)
2012 FORD F-550...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
Dewalt D28755 14" Cut-Off Machine (A59076)
Dewalt D28755 14"...
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
2025 Anvil Trailer (A56859)
2025 Anvil Trailer...
