Which mini exc.: kx71 or kx91
/ Which mini exc.: kx71 or kx91 #1
mooch
i am looking into buying a new mini exc. I have a kubota with fel now. I live on a hobby farm and usually rent a mini exc 2-3 times per year. I am ready to buy. I mainly will be digging out small stumps, ditches, some firewood work. I have a few small ponds which need some work. I want to spend less if possible but dont want to regret not getting the bigger machine. the kx91 is around 800 lbs more. Is that enough to make a significant difference? I suspect either machine will be fine but was wondering if there was a reason to go for the 91. thanks.
/ Which mini exc.: kx71 or kx91 #2
If it were me I'd get something like the U35. The zero tail swings makes a huge difference to combat our stupidity as humans. You'll see countless excavators with big knicks in the side from smashing into something. Although the excavator getting smashed is a big deal, think about what could be behind you as well. Even if it were a little smaller, I'd definitely get a zero tail swing with a compact excavator.
