Which Kubota is right for me?
   / Which Kubota is right for me? #1
Anonymous Poster
Epic Contributor
I am looking for a used Kubota (5-10 yrs old) that will satisfy the following needs:
-- Loader lifts at least 1800 lbs.
-- Hydrostatic or Reverser transmission
-- Greater than 40 hp
-- Price less than $13k
Any suggestions? It is hard to get info on older models that have been discontinued by Kubota.
Thank you.
   / Which Kubota is right for me? #2
John: can't realy give u any hard info, but go to kubota's home page and click on a series line and at the bottom of that page u will see a link that will take u to 'PRIOR PRODUCTS" u may be able to get some info there. also another site that might help u find a tractor(where ifound mine) is www.ironsolutions.com then click on search and just follow the selection options. at least gives u an idea of what is out there and the prices. good luck
   / Which Kubota is right for me? #3
JOHN,
you may have to lower you specifications. i don't know what the "M" series
will lift, but i doubt if it is 1800lbs. it is over 40hp, and i think it has a
shuttle shift, but i don't know how long they have made this model tractor.
when people buy a tractor like this, they will most likely keep it for many years.
accordionman
william l. brown
   / Which Kubota is right for me? #4
All of the Grand L series tractors lift over 2200 lbs and come in all the transmission flavors, but I don't know anything about their history. When I was shopping for a used 30+hp Kubota, I couldn't find anything in the price range you mention. Doesn't mean you won't do better, but you may have to exercise a fair amount of patience to find that really good deal out there. /w3tcompact/icons/wink.gif
   / Which Kubota is right for me? #5
We can't get down to the below $13K with a loader.
But do have some info here that meets the tractor goals.
Loader costs will range from used LA681 at $2950. and up to new at approx $3900.
In the long term... you may get a better value by shopping a little newer.
Lots of shopping tips at http://carverequipment.com/tips.htm
Good luck and happy shopping.
Merry Christmas,
Steve
USED
1999 L 3710 GST, 38 hp, 700 hr, R1s, 12,595.
1999 L 3710 GST, 38 hp, 700 hr, R4s, 12,895.
1999 L 3710 GST, 38 hp, 700 hr, loader, R1s $ 14,449.
1999 L 3710 GST, 38 hp, 700 hr, loader, R4s $ 14,749.
Program
2000 L 4310 GST, 43 hp, 4wd, 424 hr $14,249.
2000 L 4310 GST, 43 hp, 4wd, 447 hr $13,975.
New
New L 4300 DT, 43 hp, 4wd, $13,713.
   / Which Kubota is right for me? #6
Hey John:
It sounds like you're possibly looking for something a little more substantial than the grand L's.
For a few years there was a Kubota series of models at the top of the L line (they refer to them internallay as the L3 chassis). The models numbers were L3350 L3750 and L4150 from 1984 thru about 1990, and then there were 3 variants L4350, L4850 and L5450, up thu appprox 1996.
These tractors were roughly 800 pounds heavier than the newer Grand L's - everything is stronger, thicker, tubing is bigger, etc. Power was from 40 to 60 gross, 30-50 pto. They are very similar in size and weight to the present M4700, M4900, M5400 & M5700
The L4150 would be a good match for your requirements - of course if you want the best L ever made, the L5450 was the Rolls-Royce.
We're tapped into my favorite subject here - so I'll resist writing 3 pages. Contact me (rbjs@mediaone.net) if you'd like scanned or faxed brochures on any of these, or just to talk more about features.
Try a search at Traderonline (heavy equipment) for keyword kubota
Hi John, I gave up after a year of searching for a good used tractor. Everything seems to be 75 cents on the dollar even for 10 year old equipment. I bought a new B7500 and am happy that I did. Maybe you can do better. Good Luck.
   / Which Kubota is right for me? #8
<font color=blue>All of the Grand L series tractors lift over 2200 lbs</font color=blue>
Harv - Are you sure you weren't thinking of 3PH lift capacity? He was looking for Loader capacity. You don't top 1800# (at bucket center)until you get into an L4610 with LA852 loader.
   / Which Kubota is right for me? #9
<font color=blue>sure you weren't thinking of 3PH lift capacity?</font color=blue>
Oops! Apparently I wasn't thinking at all! /w3tcompact/icons/blush.gif
I was looking at the Grand L specs, and yes, that's the 3pt capacity. The LA681 loader maxes out at 1499 pounds. /w3tcompact/icons/crazy.gif It does have a breakout force of 2557 pounds. Can I save face with that? /w3tcompact/icons/laugh.gif
My bad. Call it a senior moment. Thanks for the correction, John. /w3tcompact/icons/wink.gif
   / Which Kubota is right for me? #10
Hey Jethro - I've been looking at/for tractors for 30 years - and never given up. But it is true that good used machines are few and far between. Luck favors the prepared mind. Keep looking - I've found several great tractors as I've traded along up to what I have now.
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A52577)
2012 INTERNATIONAL...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2019 INTERNATIONAL...
20 Yard Rolloff Container (A51573)
20 Yard Rolloff...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
LANESHARK LS3 LOT NUMBER 161 (A53084)
LANESHARK LS3 LOT...
1999 KENWORTH W900 TANDEM AXLE SLEEPER (A52576)
1999 KENWORTH W900...
