Which jumper cables
   / Which jumper cables #101
I made mine from 2 lengths of 20' 4ga welding cable. No more cursing them for being too short. IF I need them I hook them up and let the starting vehicle run. And run a little longer. Then I do the start. Ya know a 4ga can carry a heck of a lot of amps especially if you return some amps to the weak battery. It's not rocket science.
   / Which jumper cables #103
The reason for larger wire is to reduce voltage drop with distance. The length of the cables needs to be considered as well. The voltage drop in the cable is the product of the resistance of the cable multiplied by the current flowing at that time. Any resistance due to corrosion at the battery terminals or the wires attaching the clamp will also drop voltage. The condition of the batteries themselves can also limit current flow. This is really not a simple question but the generic answer would be bigger is generally better. Of course you can always build your own cables out of even bigger wire. Generally welding cable is more flexible than regular stranded cable.
I have found that I get get some short sections of welding cable half way reasonable and that makes the best jumper cables.A place like Royal King farm store in my area has the clamps. or most auto supply stores. I have clamped them in a vise but my preferred method is to silver solder them on. That is where most jumper cables are weakest.
Diamond C Trailers 26ft T/A Flatbed Tilt Trailer (A55787)
Diamond C Trailers...
PALLET TOTE OF MISC PARTS (A58374)
PALLET TOTE OF...
Mini-Skid Steer Vibratory Roller (New/Unused) (A59225)
Mini-Skid Steer...
PALLET TOTE OF BOTTLES & MISC (A58374)
PALLET TOTE OF...
2011 JACK COUNTY 130BBL VAC TRAILER (A58214)
2011 JACK COUNTY...
PALLET TOTE OF CERAMIC TILES (A58374)
PALLET TOTE OF...
