Which JD engines are Turbos?
   / Which JD engines are Turbos? #11
The 110 is naturally aspirated. However, the latest 110's are 134 cu.in. versus the 122 cu.in. used previously (2006 and earlier).
As noted in several threads; the 40x20's are all turboed and the 3520-3720 are turboed as well (3720 is intercooled, too.)
The 40x20's are also on the leading edge of "noisy"...
That said, everything...everything depends upon your determination of "what you want/need to accomplish with your tractor"! Whatcha gonna do with it...?
If you really want to help yourself winnow thru the pros and cons of the various tractors and how they might serve your needs the best -- hop on over to a local dealer and ask him for the keys! Fire a couple of 'em up and dig some holes in the lawn!!! (Not really; but you get the drift.)
Best of luck with your "shoppin".
AKfish
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
New Holland 57 3pt. Rake (A50775)
New Holland 57...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
UNUSED RAYTREE RMRB72 - 72" POWER RAKE BUCKET (A54757)
UNUSED RAYTREE...
CONTACT INFO (A53084)
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
