which is the better fuel???????
   / which is the better fuel??????? #1
whitearrow
philadelphia,ms
john deere 5203
hello fellas.is there any difference in shell and chevron diesel fuels?which has the better additives that would be better for your engine?any help would be greatly appreciated.
thanks,
whitearrow->>>----------->
   / which is the better fuel??????? #2
Chevron has always had a reputation for the best GASOLINE additive package.
Mike
   / which is the better fuel??????? #3
I've been told on many occasions that Shell and BP made the highest quality diesel fuel.
   / which is the better fuel??????? #4
No, no difference.
   / which is the better fuel??????? #5
As someone pointed out - branded gasoline has proprietary additives and that can make a difference - But from what I have seen diesel is pretty much diesel..
Now in winter time the amount of kerosene added may vary by terminal. Some majors also have different cetane ratings on their diesel.. Im not sure how cetane numbers are adjusted - IE is it an additive OR the way the diesel was manufactured..
If you notice at some Exxon stations the gasoline pumps are very 'branded' with the exxon name - but the diesel a lot of times is under another canopy, and the pumps may not say 'exxon' on them but just day 'diesel'. My understanding was that the diesel was just diesel - NOT an Exxon specific diesel.
thanks
Brian
Brian
   / which is the better fuel??????? #6
Fuel, both diesel and gasoline, can be proprietary but only if the fuel comes direct from a refinery or a proprietary distribution terminal. This is rare but it does happen.
Otherwise, it all gets mixed together at a non-proprietary pipeline distribution terminal. These tank farms don't have a tank for every brand of every grade of fuel so they can't maintain brand identity. One or two million+ gallon tanks for each grade of fuel is typical.
   / which is the better fuel??????? #7
Locally (Roanoke, VA), I've seen Sheetz, Exxon, Citgo, Pilot, and unbranded tankers all filling at the same fuel distribution facility.
   / which is the better fuel??????? #8
Doubt there are many additives in diesel to make much difference which brand you buy. In gasolines, all the majors generally mix their additives to meet the stringent BMW fuel injector cleanliness standards. Not sure what the story is in the diesel area.
I know Exxon sells probably about 2/3 of its products to "3rd parties", both fuels and lubes. Think some may buy the additive packages. Others do their own.
Ralph
   / which is the better fuel??????? #9
I don't know why but in my gmc diesel I get the best mileage at BP, Citgo and Shell. I have tried mobil and Exxon several times and have gotten 10% lss fuel mileage four or five times I've filled up there. It might be coincedence I don't know. For off road in my Kubota I have never noticed a difference.
   / which is the better fuel??????? #10
That's true.
CITGO is about the lowest quality you can get.....
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 JOHN DEERE...
2016 GMC 2500HD SERVICE TRUCK (A51406)
2016 GMC 2500HD...
2021 TAKEUCHI TB235-2 EXCAVATOR (A52706)
2021 TAKEUCHI...
2011 FONTAINE 48 FOOT STEPDECK (A53843)
2011 FONTAINE 48...
2015 CASE 580N (A47477)
2015 CASE 580N...
