Which is better for the long run.
   / Which is better for the long run. #1
m1garand762
ohio
kubota
Im considering an l3901, a worknmaster 40 and a 3039r. The kubota is the only machine that is self powered and naturally aspirated. I haven't heard too much positive on the turbos on the Deere and the New Holland. Dose anyone have any input. It will be used hard not a barn queen
   / Which is better for the long run. #2
I have the smaller L3301. Great little tractor with quite a bit of guts. I got the gear drive for the extra HP. Very happy with mine.
   / Which is better for the long run. #3
Personally, I like the L3901 of that group and its a tough tractor. Curious, why do you believe that tractor turbos are not reliable?
   / Which is better for the long run. #4
I have no experience with any of the three. I am a firm believer that simpler is better, though.
   / Which is better for the long run. #5
I will take exception to the Op's statement on turbos. I can't remember a thread here on TBN regarding problems with turbo's on any brand tractor.
And one of the MAJOR factors regarding tractor longevity - the quality of the maintenance done on the tractor.
   / Which is better for the long run. #6
Just Google "when were turbo chargers first used on diesel engines". You will find that turbos have been used for almost a century. It is not a new or fragile technology.:2cents:
   / Which is better for the long run. #7
JD has a Yanmar engine and Workmaster is the LS - all very good machines, but if you want a true ALL OEM machine, then the Kubota is the choice.
If you own a Kubota now why change, what are your use cases - what do you want to do? Regarding your comment "not a barn queen, it will be used hard" they all will work hard, as long as you in return take care of the machine - it goes both ways - you take care of it and it takes care of you.
   / Which is better for the long run. #8
Of those three I would go with the Kubota, but turbos are fine if you take care of them. If you have been running the tractor hard, let it idle for a couple of minutes before you shut it down and make sure you keep up with oil changes and use good oil.
Actuall in the new holland section rhere are some and they all relate to cold weather and failure along with the egr
   / Which is better for the long run. #10
Another vote for the L3901 . If the polling stations still open .
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2000 Ditch Witch 3700DD Ride-On Trencher (A50322)
2000 Ditch Witch...
Ford 4600 (A50120)
Ford 4600 (A50120)
2001 Same Argon 70 (A50120)
2001 Same Argon 70...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
