which iMatch compatible RFM?
/ which iMatch compatible RFM? #1
jmt1271
Platinum Member
MO
Kubota L2501
I am in the market for an RFM to pull behind my 3520. It needs to be iMatch compatible. I think I want a 72". I am replacing a Cub GT 54" as I am going to be mowing 5+ acres. I am unsure which models will work with the iMatch and need help from more experienced users. Thanks.
/ which iMatch compatible RFM? #2
The Frontier (WOODS) RFM are Imatch compatible. Some models require an extra kit that takes about 5 minutues to put on. Works very good. I had a RM1072 with the imatch kit. My dealer is also a Bush Hog dealer and he told me that the BH brand is NOT imatch compatible, but the Frontier was the same price.
John
www.buyfrontier.com
www.sun-guard.com
/ which iMatch compatible RFM? #3
I have a 72" Buhler Farm King RFM that I used for a long time without an i-Match. Recently I bought one and had to order a special kit to make it i-Match compatible. However, the kit didn't completely solve the problem on the bottom two lift pins and I had to buy two replacement speeco pins without the shoulders. Together with either a sleeve or a set of bushings (converting it to cat3), it now works fine.
The Buhler unit has worked well for me and I bought it from my local Deere dealer when I got my 4600. They sell these instead of Frontier as they are considered to be a better performing unit. If your criteria is which mower is i-Match compatible, you can go with either. Good luck.
-Bob
2013 Ford F-150 Pickup Truck (A61568)
2013 Ford F-150...
2716SFL (A61567)
2716SFL (A61567)
2000 Freightliner Discovery 36T 36ft. Class A Motorhome (A61569)
2000 Freightliner...
(APPROX. 60) UNUSED MISC SIZE RATCHET STRAPS (A62130)
(APPROX. 60)...
2024 Blue Diamond Skid Steer Vibratory Roller (A63116)
2024 Blue Diamond...
2014 Chevrolet 2500 Savana Van (A63116)
2014 Chevrolet...
