Which IH small tractor am I recalling?
/ Which IH small tractor am I recalling? #1
RonR
Kansas
2003 BX2200
As a youth, I used an old IH tractor that had a sickle mower behind it. I thought it was called a "C", but after seeing other pics here, it was definitely not a "C".
It was much smaller than a "C", and had a very WIDE rear wheel base. The operator sat to the right of tractor, with clutch and brakes both to the right of the main body. I think it was tricycle, but it was a long time ago. The rear tires were about 2/3rds the size as on an 8N Ford, as I recall. Any clues which one it was?
Any links to old IH pics? THANKS.
ron
/ Which IH small tractor am I recalling? #2
The farmall offsets were the Cub and A/super A.
Ben
/ Which IH small tractor am I recalling? #3
There were several models that had the Cultivision offset.
You may be thinking of a A.
Here is one on EBAY that may show what you want. Click Here
I had a Cub with sickle mower attachment. But do not remember how it was mounted.
My Dad had a A that we used for many years. Think he got rid of it around 1965.
/ Which IH small tractor am I recalling? #4
If it was a tricycle front end, I believe it was a "B". I think all the "A"s and Cubs were wide front, B's were narrow, and C's on up could be had either way.
/ Which IH small tractor am I recalling? #5
Sounds to me like you are talking about a Farmal B. It was a narrow front end and could be either a single or double narrow front ent. The operator sat ofset, with the clutch and brake on a small platform to the right of the center of the engine, about 19 hp with a 4 sp trans that was on the drivers left. Thry wern't made many years and the Farmall C took it's place it the Farmall line as the smallest 2 row tractor.
Later, Nat
/ Which IH small tractor am I recalling? #7
Neither can I and I'm the one that posted it. I'll try again
/ Which IH small tractor am I recalling? #8
That works. /forums/images/graemlins/grin.gif
You could have done a edit on your original post to repost the picture.
/ Which IH small tractor am I recalling? #9
Only the cubs and the A's were offset in the letter series.
I sort of understood that this was an offset tractor.
Ben
Thanks for all the replies.
The IH was definitely offset, and probably the size of an "A".
What my memory says though (and it might be foggy) was that the rear axle spacing was twice the width of the pics shown here.
Sure would like to find something that size to play with now.
I've owned a 49 JD M, then a McCormack 15-30, and I want to go SMALLER now.
THANKS.
ron
/ Which IH small tractor am I recalling? #11
This part of PA seems to be IH country, more often than not farms that are still working are running one or more 66 series IH's from the seventies, and you still see an occasional H, M, or hundred series on the 2nd or 3rd string doing raking or pulling a wagon.
Not too hard to find an "A", "Cub" or "H" around here. "C's" seem to be somewhat less common and "B's" rarer yet, but none seem all that hard to find and the prices are pretty low. If you're not strongly inclined to sticking to only the old 'letter' series - the later hundred series are out there. I think the "A" was made (in final form as the 140) right up to the mid-sixties.
/ Which IH small tractor am I recalling? #12
Wasn't the A made through the 140 series clear up till '76? I thought I read that in one of my books on IH, but am not totally sure without the reference in front of me.
/ Which IH small tractor am I recalling? #13
Might well have been - the IH 'data book' I have handy in my desk drawer at work only covered up through the 130 (which ended in 1958) so I was guessing from memory on the 140.
A late 140 has a lot of 'practical' advantages over an early A, but I still like the original Lowey look of a letter series. /forums/images/graemlins/grin.gif
/ Which IH small tractor am I recalling? #14
Hi Ron,
I have a 42 A and 49 Super A, I have the rear mount sickle model #16A for the 42A. Im kinda thinkin thats what you saw /forums/images/graemlins/grin.gif
scotty
/ Which IH small tractor am I recalling? #15
To my understanding, the A and the B were basically the same tractor, the operator set to the right side of the tractor. The A had a short axle on the left side of the tractor and a long axle on the right side, where the operator sat. On the B, the operator sat on the right side of the tractor same as on the A, but the B had a long axle on the left side of the tractor also which gave it a wide stance therefore the only offset being the operator platform and the operator, the engine and drive train on the B was not offset as on the A.
/ Which IH small tractor am I recalling? #17
I am thinking it was a "B" if it had a really WIDE rear. The "C" replaced it around 1948 or '49.
/ Which IH small tractor am I recalling? #18
The A and B are the same except for the offset engine and operators seat on the right on the A. I believe the engine and such are the same. All the A's I have seen had wide fronts and all the B's I have seen had narrow fronts. I suppose the B could have a wide front, but I have not seen any. The C is a larger tractor and are not offset. The CUBS are like a smaller A, being offset.
Ben
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
2007 Mack CHN614 Day Cab Truck, VIN # 1M1AJ06Y97N005399 (A65563)
2007 Mack CHN614...
2006 Western Star 4900 Concrete Mixer U98358 (A62613)
2006 Western Star...
2015 JLG G12-55A TELEHANDLER (A65643)
2015 JLG G12-55A...
2010 Mercury 15HP Tiller Four Stroke Outboard Boat Motor (A64557)
2010 Mercury 15HP...
