Oil & Fuel Which Hydraulic Fluid?
   / Which Hydraulic Fluid? #1
bradrich18
Bronze Member
Central Alabama
John Deere 1026R
It's almost time for my 50 hr service on my 1026r which requires changing the transmission fluid and filter. My owners manual says to use Low Vis Hy Gard hydraulic fluid. The parts salesman at the JD dealer I went to told me to use regular Hy Gard because it was better suited for our region (central Alabama). I want to make sure this machine is taken care of. Does it matter which fluid I use? Thanks.
   / Which Hydraulic Fluid? #2
I'm thinking low vis is the "default" fluid because it is suitable for all regions. Considering your geographic location the regular Hy Guard would be just fine,as your dealer stated.:)
Greg
   / Which Hydraulic Fluid? #3
Either will work just fine, but I would listen to your dealer.
   / Which Hydraulic Fluid? #4
I'd go with the owner's manual. Unless you never have plans to use the tractor and/or hydraulics in temperatures below 30F. Then the regular HyGard will be fine. It's about 20W, as opposed to 10W for the low-vis. Keep in mind, this is a common sump tractor. The fluid operates the transmission AND the hydraulics. On individual sump tractors, the hydraulic fluid of choice for cold climates is AW32 (10W equivalent). Choice for moderate climate is AW46 or AW64 *(20W), warm climate AW100 (30W).
//greg//
2016 CIMC 40FT CONTAINER CHASSIS (A52141)
2016 CIMC 40FT...
Unused 2025 CFG Industrial MY50R Mini Excavator (A50322)
Unused 2025 CFG...
2015 Jeep Renegade Latitude SUV (A50324)
2015 Jeep Renegade...
Tiger Mowers 90in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 90in...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A50322)
2023 Caterpillar...
