Oil & Fuel Which hydraulic Fluid to use.
   / Which hydraulic Fluid to use. #1
Localboy
oroville ca
mitsubishi D1600
Recently, purchase a Mitsubishi D1600, gray tractor, and the lift arms ceased working. They had moved before.
Can someone tell me the proper fluid and amount. Understand they use the same fluid as the hydraulics.
Is working on the lift cylinder a difficult job?
Thanks for your help.
r
   / Which hydraulic Fluid to use. #2
Get a shop manual and some TSC hydraulic fluid.
   / Which hydraulic Fluid to use. #3
   / Which hydraulic Fluid to use. #4
there is a small lever under the front of the seat that you can move from right to left. Most likely you bumped it. If the FEL is working then that is what happened.
JARRAFF TREE TRIMMER (A52706)
JARRAFF TREE...
8' LARGE FENCE POSTS (APPROX. 20-25 PC) (A54757)
8' LARGE FENCE...
2016 Ford F-250 Ext. Cab Pickup Truck (A53422)
2016 Ford F-250...
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
UNUSED PROFESSIONAL X2600A ELECTRIC CONCRETE MIXER (A54757)
UNUSED...
