Oil & Fuel Which hydraulic Fluid to use.
   / Which hydraulic Fluid to use. #1
Localboy
oroville ca
mitsubishi D1600
Recently, purchase a Mitsubishi D1600, gray tractor, and the lift arms ceased working. They had moved before.
Can someone tell me the proper fluid and amount. Understand they use the same fluid as the hydraulics.
Is working on the lift cylinder a difficult job?
Thanks for your help.
r
   / Which hydraulic Fluid to use. #2
Get a shop manual and some TSC hydraulic fluid.
   / Which hydraulic Fluid to use. #3
   / Which hydraulic Fluid to use. #4
there is a small lever under the front of the seat that you can move from right to left. Most likely you bumped it. If the FEL is working then that is what happened.
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2013 Chevrolet...
Trail King 20ft T/A Flatbed Equipment Trailer (A51691)
Trail King 20ft...
2001 Ford Ranger Pickup Truck (A51694)
2001 Ford Ranger...
