Which hydraulic fittings on M59 backhoe
   / Which hydraulic fittings on M59 backhoe #1
rScotty
Super Member
Rural mountains - Colorado
Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
It is time to to replace the hydraulic hose to the factory thumb on our M59. Any hints gratefully accepted.
Does anyone know the fitting size and type? I'd like to get some end caps just to keep things clean.
I assume the fittings are JIC, but the manuals don't say which or dash size. The basic backhoe for the M59 is the BT1200 - although it becomes a BT1200v when the thumb is factory installed.
Thanks,
rScotty
   / Which hydraulic fittings on M59 backhoe #2
On the densely populated east coast there is a dense population of hydraulic machinery that supports a dense population of repair shops. Within 5 miles of me there is a Hope Group (Formerly Parker) that will make new hose with fittings while one waits. Some equipment operator, like the local highway department, may know or recommend the closest such shop to you even in rural CO. The premium for fast service and the cost of travel may still be economic.
   / Which hydraulic fittings on M59 backhoe #3
Get out your calipers, thread gauges and measure it. The easiest to measure are the male ends. The hose itself may give a clue as well--The metal crimp sleeves sometimes have part numbers stamped in them.
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
2000 SCHWING P88 PORTABLE CONCRETE MIXER (A51247)
2000 SCHWING P88...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
4 MISC TIRES (A53843)
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
