Which hand tools to keep on tractor?
   / Which hand tools to keep on tractor? #1
Bacon
Washington DC
Kubota MX5100 DT (in progress)
Let me start by saying this is a great forum用acket with information妖ry humor and some real wisdom (and enough craziness to make it interesting). Here is my situation:
I am in the process of acquiring both a bit of property (31 acres) and a MX5100 DT w/ FEL to keep it in line. Very excited. Usual attachments: rotary cutter, rear blade, box blade, PHD.
Not having any experience with this sort of thing, I want to know which hand tools I should purchase for on the spot adjustments and repairs i.e. hammer (type? Weight?), wrenches? Crowbars? Cyanide capsules, etc. etc.
I am trying to avoid my usual M.O. when starting a project of running to the hardware store every two hours to pick up something I forgot and/or don稚 need!
Thanks-
-J.
   / Which hand tools to keep on tractor? #2
hello the tool box on most tractors will not hold enought....but here some... duck tape or electrical tape....pryers..screwdrivers...good wire cutters...extra bolts alittle long than normal that way they can be a use a number of places on mower or tractor...clip for pins...hammer...baling wire...washers nuts....and so on...Howard
Thanks. I should have thought of duct tape! As far as the onboard toolbox goes, I have seen a couple of threads on how to mount an extra toolbox, and will have to look into that. As long as it only involves punching a couple holes in box and frame/fender I should be fine--welding on a right side mounted frame is a bit beyond my abilities---I have also seen people mention that they keep pruning shears and saws handy just in case they spot something worth trimming while on another task.
   / Which hand tools to keep on tractor? #4
Thanks-
-J.
I don't keep tools to repair the tractor in the tractor. I've never found that I had the right tool anyway and I usually pull a truck up with all of my tools handy. Frankly, I've never worked on the Kubota out in the field, different story with my older tractors.
I find a 3 pound hammer very handy for making fine adjustments when connecting to impliments. I have a crowbar behind the seat, mostly for prying up rocks as I come across them. I keep a limb pruner there too to nip branches that get in the way of mowing. A can of bug spray in case you have to get off the tractor in the weeds. A couple of extra pins and clips.
   / Which hand tools to keep on tractor? #5
Around our parts, that can of bug spray is going to be used on hornets, bees and and what are sometimes called "meat bees", which are actually wasps.
Run over a nest and you need instant knock-down protection. Guys have have tractor accidents while being attacked by a swarm of stinging insects...
   / Which hand tools to keep on tractor? #6
Bacon said:
Not having any experience with this sort of thing, I want to know which hand tools I should purchase for on the spot adjustments and repairs i.e. hammer (type? Weight?), wrenches? Crowbars? Cyanide capsules, etc. etc.-J.
Don't know about your toolbox, but mine will only hold 3-4 small tools. I like to keep Vice grips, regular and phillips screwdrivers, diagonal pliers, ball peen hammer, wad of bailing wire, lynch pins, hair pins, and with 31 acres, I recommend a small roll of toilet paper. ;)
   / Which hand tools to keep on tractor? #7
Much more than some pliers and an adjustable spanner is probably overkill. :D :D Most repairs will require an assortment of tools that are very difficult to carry in a tractor toolbox.:D :D
The plastic bag of paper may be the most important!:D :D
   / Which hand tools to keep on tractor? #8
Here's my personal list:
grease gun in bracket on fender., small pry bar.. screwdriver, reg/philips.. or nut driver with adapter and heads. wire cutter, small roll of bailing wire, small roll of insulated wire/gator clip test wire. electrical tape, adjustable wrench, gas pliers. fire extinguisher, 1st aid kit.
soundguy
Well, I suppose if I keep a fire extinguisher, first aid kit, AND toilet paper with me I should be covered for all sorts of accidents!
---Also, can I just say: "meat bees"...that conjures an image in my head that I think will never go away. If they ever come after me while I am on the tractor I suppose the toilet paper will come in handy for dealing with the aftermath.
   / Which hand tools to keep on tractor? #10
I believe those are called 'brown alerts!'
soundguy
UNUSED FUTURE VR66 66" VIBRATORY ROLLER (A51248)
UNUSED FUTURE VR66...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
2025 CFG Industrial MX50R (A50123)
2025 CFG...
2011 Ford Flex SUV (A53117)
2011 Ford Flex SUV...
UNUSED WOLVERINE TL-12-72W - 72" HYD TILLER (A51248)
UNUSED WOLVERINE...
2006 JLG 660SJ SKYPOWER MANLIFT (A51246)
2006 JLG 660SJ...
