Which grinder should I get?
   / Which grinder should I get? #1
General Lee
Mid-Atlantic
Kubota L4400, B2401
I've been wanting to get a grinder, just never needed one very often. Now I need one because I am cleaning up an old steel wagon wheel. Need to get the rust off before painting it. I envision a standard angle gringer preventing me from getting in between the spokes, especially at the ends where they meet the wheel and hub.
I picture using a good sized dremel but have never seen one that would take a decent size attachment that won't leave me grinding for days. What do you all recommend?
   / Which grinder should I get? #3
die grinder.. angle grinder and a needle scaler.
probably get all 3 for 60$ from harbor freight...
between the 3 you will be a rus removing sob....
   / Which grinder should I get? #4
Another vote for needle scaler...
Put knotted wire wheels on your grinder
   / Which grinder should I get? #5
Unless you are envisioning a lot of projects like this in the future (which it sounds like you don't) I would get an angle grinder just because they are good to have around but would take the wheel in to get it sand blasted. It will do the best job and would cost less than buying any purpose built item to use one time.
I have the option to sand blast it, a friend of mine has a machine. That was my original plan but I wanted to work on it this week and not sure if I'll have access to the sand blaster.
I'm liking the needle scaler. I've seen them before just didn't know what is was called.
   / Which grinder should I get? #7
any results?
   / Which grinder should I get? #8
just a note:
sandblaster will remove rust quickest with least amount of material removal, the surface will be very good for painting afterwards, just be sure to use good material, sand is generally silica based, bad for lungs and painting on.
grinders of any type will remove material leave scratches and hard to get into all areas easy.
I would suggest getting a 4-1/2" one from HF 20 bucks well spent.
same for air tools die grinders etc they all remove metal but work well, hard to get into all areas. I have a pretty good set all from HF and have not had an issue with them yet.
anyhow spokes are an issue for ANY type of rust to get off, takes a while for sure... I bought one of the HF cabinet blasters to do a bunch of small brackets for a car rebuild. happy with it, but have blasted outside with hood and disposable type blasters that work as well.
MARK
   / Which grinder should I get? #9
i like a knotted cup on a angle grinder.. less metal removal.. if any.. but eats rust and paint.. 3m black pad works good too.. but goes away in bout an hour.. :)
   / Which grinder should I get? #10
Any grinding wheel is the wrong tool by the way. You want it sandblasted or, if you have a good compressor, you want wire wheels and a needle scaler.
1996 Lincoln Town Car Sedan (A50324)
1996 Lincoln Town...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2025 Future Stump Grinder Mini Skid Steer Attachment (A50322)
2025 Future Stump...
Dodge Charger (A50324)
UNUSED X-STAR SKID STEER 72" LAND PLANE (A51243)
UNUSED X-STAR SKID...
JOHN DEERE 524L LOADER (A51242)
JOHN DEERE 524L...
