Which grease?
   / Which grease? #1
eyal
Hello!
Im sorry of my bad english.
I have John Deere 694 corn header, and i want to know which grease i need to use?
Eyal.
   / Which grease? #2
Dear Sir
I am not familiar with your model of machine. I would suggest a general purpose grease, EP1 ( this means extreme pressure grade 1 thickness ). This class of grease is sold as for roller ,ball , wheel bearings , and tierod ends. A bearing should only be 40% filled with grease.
Craig Clayton
   / Which grease? #3
Depends on what you are using it for. JD does make a special "corn head" grease, it is really an oil lubricant suspended in a thickener. It doesn't get slung out of the way, and is used in many gearbox applications. I've read 90+ wt oil can be substituted, but do your own research
   / Which grease? #5
yep.. we need to know where you want the grease, as the header boxes use that thin grease. for other generic locations, pivot points, wheel bearings.. etc.... regular gun grease should be fine.
soudnguy
2016 HINO 195 16FT BOX TRUCK (A54607)
2016 HINO 195 16FT...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A55302)
2020 New Holland...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A52377)
2015 Peterbilt 579...
2017 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Terex TLM40 Boom (A55218)
2017 RAM 5500...
UNUSED PROFESSIONAL X2600A ELECTRIC CONCRETE MIXER (A54757)
UNUSED...
