Which grease?
   / Which grease? #1
eyal
Hello!
Im sorry of my bad english.
I have John Deere 694 corn header, and i want to know which grease i need to use?
Eyal.
   / Which grease? #2
Dear Sir
I am not familiar with your model of machine. I would suggest a general purpose grease, EP1 ( this means extreme pressure grade 1 thickness ). This class of grease is sold as for roller ,ball , wheel bearings , and tierod ends. A bearing should only be 40% filled with grease.
Craig Clayton
   / Which grease? #3
Depends on what you are using it for. JD does make a special "corn head" grease, it is really an oil lubricant suspended in a thickener. It doesn't get slung out of the way, and is used in many gearbox applications. I've read 90+ wt oil can be substituted, but do your own research
   / Which grease? #5
yep.. we need to know where you want the grease, as the header boxes use that thin grease. for other generic locations, pivot points, wheel bearings.. etc.... regular gun grease should be fine.
soudnguy
Galvanized Livestock Gates - (6x Total Gates) (A55218)
Galvanized...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
2004 Sterling Acterra Cab and Chassis S/A Truck (A54814)
2004 Sterling...
UNUSED LANDHONOR LHR-LB9510 GAS LEAF BLOWER (A54757)
UNUSED LANDHONOR...
UNUSED LANDHONOR 82" FORK EXTENSIONS (A54757)
UNUSED LANDHONOR...
